Ammo 2300 0r 2600?
  • ibyte
    • Sep 2008
    • 83
    you guys are great. I dont like using esc that arent at leat water resistant or water cooled, but of course water is very dynamic in property and it finds its way into anything. That being said and i promise not to ask again , what if any performance gains did you notice with the ammo 2300? and where o where did you put your sv motor and esc after you upgraded? i would like to keep the stock esc on the sv so the ammo 2300 works for me. Thank you all for the suggestions theres nothing like OSE for advice......see you all in the water
    • Diegoboy
      • Mar 2007
      • 7443
      Originally posted by ChaKane View Post
      I would suggest the 2600. If you are running 7.4 volts in parallel, then you are still only running 7.4 volts. I wouldn't think that the 2600 at 7.4 volts would draw too much current for the standard ESC.
      Isn't the Ammo motors input voltage a bit higher than 7.4 to be efficient?
      Originally posted by Tower Hobbies
      2300
      SPECS:
      Motor Diameter: 1.42" (36mm)
      Motor Length: 1.97" (50mm)
      Shaft Diameter: .197" (5mm)
      Shaft Length: .591" (15mm)
      kV Rating: 2300 rpm/V
      Weight: 8.6oz (243g)
      Input Voltage: 14.8-18.5V
      Max. Constant Current: 60A
      Max. Surge Current: 100A
      Max. Constant Watts: 110W
      No Load Current: 2A
      2600
      SPECS:
      Motor Length: 2.2" (56mm)
      kV Rating: 2600 rpm/V
      Weight: 10oz (283g)
      Input Voltage: 11.1-14.8V
      Max. Constant Current: 55A
      Max. Surge Current: 90A
      Max. Constant Watts: 815W
      No Load Current: 3.9A
      • coollio
        • 23
        hi
        Does anyone know if there's any need to drill the motor bracket in order to mount the Ammo motor? Or its a direct bolt on?
        • ChaKane
          • 131
          Ibyte - I would prefer on the water than in it.
          Coollio, not sure about the ammo but Feigao is a bolt on. I'm not sure but I would say that most just bolt on.
          • coollio
            • 23
            Feigao is a bolt on? Which model n how abt the shaft?
            • Diegoboy
              • Mar 2007
              • 7443
              They are all bolt on (standard mounting holes)
              • coollio
                • 23
                Hi Diegoboy, Since they are all direct bolt on any advise which one shld i go for? Ammo or Feigao?
                • Diegoboy
                  • Mar 2007
                  • 7443
                  That depends on what you are putting it in, and which Feigao.
                  2 AMMO MOTOR VS. 23 FEIGAO MOTORS.
                  • coollio
                    • 23
                    Care to recommend me a model to go for? btw do i need to change the ESC if im changin the motor?
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      you're in the SV board, so I'll assume you like V hulls. Although the SV27 is a great starter boat, I, and others, don't like how it spends a lot of time upside down. Continuing with the assumptions, I'll assume you want RTR. RTR V hull? I'd get the Pro boat Fastech. It's not a pretty boat, but it runs well. I'm making one a Jet boat!
                      Again that has a lot to do with the boat and which motor. Assuming you go with the Fastech, keep it stock first, then we can talk about upgrades!
                      • domwilson
                        • 4411
                        Alot of people do the Ammo 2300 as a direct replacement for the stock motor. You may need to prop down slightly. But there are some that use the X440 prop with no problems.
                        Government Moto:
                        • coollio
                          • 23
                          Tks for r recommendation! Cheers...
                          • ibyte
                            • Sep 2008
                            • 83
                            would the CF 45 or 48 props be to much? for the ammo 2300? i have a bunch of them just want to get it right as they work really well with the stock sv motor. I have tried to research the forums and other sites and was wondering is the ammo 2300 more a replacement motor or a upgrade?
                            • domwilson
                              • 4411
                              The CF45 would probably be too much for the motor/ESC. The Ammo is intended as an upgrade because of the higher KV. However, you will need to start with a smaller prop like the x437, x637, x440, x640 etc. because it is a 2 pole motor and does not have the torque as the stock motor. I have read that some guys may even use a x642 with this motor, but of course, there was an upgrade to a higher amp ESC.
                              Government Moto:
                              • ibyte
                                • Sep 2008
                                • 83
                                Thank you for the reply. i knew it i knew it i should have researched more on the motor and prop combos well im off to the OSE store.thanks again im buying every prop you just mentioned if steve has them
