supervee perfect ?
  • fullthrotteljunkie85
    • May 2016
    • 39
    supervee perfect ?
    I ran my supervee 27 today and without the adjustable trim tabs i ordered it is running across water almost perfect ,not bouncing just skimming across but seems slow when its trimmed this way. Ive ordered a dynamite 2000kv just for extra rpm on 4s compared to my stock blue motor..with my 120amp seaking esc, so maybe having motor,turnfin for left side,adjustable tabs will increase speed a good bit. Whats yalls idea or thoughts on this? What is the perfect riding condition
    • May 2016
    • 39
    also using a grim racer 42/55 prop is that slowing me down? currently with my stock motor? When i get new motor what could i run to get speed?
      • 7512
      The SV has limitations on the speed before the stability gets way out of control. Is it running wet?
        • May 2016
        • 39
        the boat is preety dry on front end
        • NativePaul
          Greased Weasel
          • 2770
          If it is running dry and stable, don't change a damn thing, we have found who got the good one.
            • May 2016
            • 39
            thanks doby and nativepaul, i did get my adjustable trims in and the other turn fin so maybe when I get motor in if it even helps speed it will be stable at faster speeds
              • May 2016
              • 39
              so i ran my supervee today with dynamite 2000kv and 120esc on 4s with a plastic 2 blade prop 40mm and after 2nd run of about 10minutes each the back of the prop cable broke off and lost prop and end of cable in water. What causes this? when i put new motor in i took my grimgrease and grease cable too.
                • May 2016
                • 39
                does the upgraded flexshaft from kintec racing better? I gotta get it fixxed soon but if a stocker breaks easy i may not get lucky and had close to bank to retrieve.
