upgrading water jacket
  • KevinThompson
    • Sep 2008
    • 14
    On the stock motor, can someone point me to the best upgrade water jacket? I also just have the stock water pickup.
    Thanks
  • kck741
    • Aug 2007
    • 265
    You can get the OSE water jacket here,works well.But in the time being you can turn the stock water jacket around for better cooling,face the inlet and outlet of the jacket twards the front of the hull,you will see a difference in how much more water it puts out and how much cooler the motor is
    S.S.R.C-Southern Style Radio Control
    • SweetAccord
      Speed Passion
      • Oct 2007
      • 1302
      Greetings,
      This is a well made aftermarket one for the stock motor: http://www.offshoreelectrics.com/pro...od=ose-mjacket
      • KevinThompson
        • Sep 2008
        • 14
        Originally posted by SweetAccord View Post
        Greetings,
        Thanks I'll get that one
        • ibyte
          • Sep 2008
          • 83
          Kevin while you are at it you might want to look at upgrading other things on the boat. props,turn fins, trim tabs thats if your wallet allows but worth every dollar.
          • KevinThompson
            • Sep 2008
            • 14
            thanks it has adjustabale tabs and a 2 blade brass prop I'm not sure what kind, the boat is quick enough for me with that prop. I ordered the jacket, a port side fin and some grease. This spring I'll get some lipo's and a decent charger but fall is here and I'm thinking about snowmobiling and ice fishin now :)
            • Dr. Jet
              • 1707
              What about this one. It looks like it has a bit more mass.
              http://www.offshoreelectrics.com/pro...=ham-jack-540S
              • ibyte
                • Sep 2008
                • 83
                sounds good Kevin. ya those holes you drill in the ice are way to small to run the Super V Good fishing to you Kevin i see you cacthing the big one this winter!!
