Aquacraft 45amp esc question
  • Tamelesstgr
    • Jun 2014
    • 1512
    That's interesting thought because I will be doing a build for my younger son soon maybe next season when he has more driving experience. I've been wanting a BBY mono.
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • gearhd48
      • May 2015
      • 139
      For what it's worth I was running the AQ2030 with the 50amp AQ ESC and 11.1 50c 5000 in mine before I got the new version and it moved well and was a good set up for a newbie. plenty run time and about 29 - 33mph. forgot what prop though. 2 cents worth The hobbyking ESC t,s davis suggested are great in the SW26 for real fun speeds!
      SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.
      • Tamelesstgr
        • Jun 2014
        • 1512
        In 2 weeks I am on vacation with the family, I plan on doing some through testing. Baseline with the 8.4 nimh, then a 2s, and my 3s pack is coming today. I've got to collect a lot of information because I believe it will help me understand all these parameters and how it equates to either speed or overloading the setup. I'll be doing GPS Speed and temps as well. GT Watt meter just arrived so I can get actual run max measurements versus the Hobby King unit I have that only shows bench testing or dropping the boat in a tub.
        • RCBoaterGuy
          • Dec 2014
          • 203
          No, actually it has more to do with the motor & hull\boat design...
          1. - it's a 2-pole BLM, they take a couple seconds to wind up.
          2. - I too have one of these boats setup in a very similar manner. Starts off with the nose way up in the air, starts leveling off, then gets on plane, then takes off like a jack rabbit. Mine has a 2000Kv 2-pole motor running on 3S with a Seaking ESC (7.5-degrees timing).
          Get on You Tube & check out vids of the SW26 version-3's... NOT THE GREEN ONE's - these one's... http://www.proboatmodels.com/Product...ProdID=PRB0650 - they're rebadged \ relabeled \ re-marketed \ re what-ever you want to call it Impulse 26's... http://www.horizonhobby.co.uk/marine...mpulse_26.html - originally designed to run a 550 brushed motor.
          Maybe, just maybe the prop might be a bit too much for his setup. The factory prop on these boats is a plastic Prather S215 - 40.6mm dia x 2.5" pitch. Maybe, just maybe, he should try a x440 or x442 - CNC or S&B Octura, his choice.
          FYI: Travis is running a CNC x443 on his green 60mph rocket ship.
          Heres your problem...
          "Input Voltage: 12-14 NiMH, NiCd cells"
          AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
          Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
          Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
          • Tamelesstgr
            • Jun 2014
            • 1512
            I plan on some sharpened and balanced props once I am done gathering data on the various 1.4 pitch plastic props I have. Want a good understanding of what works well before plunking down $ for a custom prop.
            • RCBoaterGuy
              • Dec 2014
              • 203
              Tim,
              The 45-amp version doesn't need 4S to arm correctly - the 60-amp version does because it has built in LVC & stutter bump.
              I used one of the 45's in a boat years ago, single 7-cell NiMH pack armed it just fine & the boat ran fine. 15+ mins runtime no prob. x442 prop.
              Terry,
              The version-2 Turnigy's are disco'ed just like there Seaking brothers. Everything is V3 now unless you shop the forums for a V2.
              Included links are dead BTW...
              Exactly. Later versions ( actually current version-60amp ) will only arm if supplied with 4s which is 14.8v.
              Your voltage is too low between 1-7 cell for the ESC to arm.
              Sent from my D6708 using Tapatalk
                • 5660
                Originally posted by RCBoaterGuy View Post
                Tim,
                This was for the SV27R as far as I can remember and the spec says input between 12-14 NiMH...... Most of the owners of that boat at that time if not running lipo batteries would have used either 12 or 14 cell packs of NiMH.
                I am glad that it worked for you with 7 cell.
                • Tamelesstgr
                  • Jun 2014
                  • 1512
                  Just a quick update, running 3s lipo I have not encountered any further issues, pretty much always moves with throttle blip. Still a little bit of a step with lower rpm then into the full range, but acceptable.
