whats negative blue or yellow.
  • dubkatz
    • 15
    hi i just cut the bullets of the stock esc. going to put them on another esc. and i forgot to mark which wires were wich. I know you can alter the + and - to change the direction of the motor. but the signal wire has to be correct. is the signal wire the yellow or blue wire? thanks
  • RCprince
    • Jul 2007
    • 1684
    Yellow, Blue? the wire that run to the motor are non polarized, they are working in a form of Alternating current, it doesn't matter unless the motor spins in the direction you don't want.
    Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
    • ghostofpf1
      • 399
      Just connect them in a random manner and reverse any two if the motor spins in the wrong direction
      hth
      ghost
      • Doug Smock
        • 5359
        You don't want to do that.
        Like the guys have said, connect the motor, if it runs backwards, reverse any two MOTOR leads.
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • Ocean Racer
          • 511
          or reverse the throttle on the radio
          Failure is the First step to SUCCESS
