OSE Water Cooling Jacket
  • SweetAccord
    Speed Passion
    • 1322
    Just wanted to share something with you all, maybe some already know, maybe there was not enough grease on the install but;
    This item http://www.offshoreelectrics.com/pro...ham-jack-540XL does not appear to fit on a 36-50 AMMO motor. It's fine on the Feigao's. Only http://www.offshoreelectrics.com/pro...mjacket&cat=42 appears to fit the AMMO's. Maybe it's me?
    Peace~
  • Steven Vaccaro
    Administrator
    • 8932
    We now have a jacket just for the ammo 2300 motor. The ammo 2300 seems to come in a couple of different sizes, making fitting a bit difficult.
    Steven Vaccaro
    • Avanti
      • 1298
      the ammo is a true 36mm diameter
      the xl motors are not
      The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
      • Steven Vaccaro
        Administrator
        • 8932
        How many ammo's have you measured? Also check them in different places. They are not completely round!
        Steven Vaccaro
        • Avanti
          • 1298
          I have a 3656 2600 and a 3650 2300 standard jacket works fine, but on my 7xl the o-rings need to be pushed in past the groove to seal.
          • SweetAccord
            Speed Passion
            • 1322
            So can http://www.offshoreelectrics.com/pro...ham-jack-540XL fit on an AMMO 3600? It's deminsions are the same as the AMMO 2300.
            • Avanti
              • 1298
              that is the smaller jacket it most likely will not work on the ammo 36mm motors
              • SweetAccord
                Speed Passion
                • 1322
                That stinks, there is no water cooling jacket out there that is long like the 540 XL Cooling jacket that would fit the 2600 only the shorter ones.
                • Avanti
                  • 1298
                  check ebay etti makes a long one or you can run two sv coolers
                  • Avanti
                    • 1298
                    heres the link you want the 540 size, they have 30mm long to 60mm long I run the 50mm
                    • SweetAccord
                      Speed Passion
                      • 1322
                      Sweet! Thank you! Too bad Steve does not carry these. I'd rather give him my business.
                      • Ub Hauled
                        • 3051
                        I'm sure he's looking into this as we speak
                        • SweetAccord
                          Speed Passion
                          • 1322
                          I hope so, I'll wait on it then.
                          • Steven Vaccaro
                            Administrator
                            • 8932
                            The 2300 and 3300 are the same length. So the Ammo 2300 jacket should fit the 3300 motor if the diameter is the same.
                            http://www.offshoreelectrics.com/pro...=ham-ammo-jack
                            Steven Vaccaro
                            • SweetAccord
                              Speed Passion
                              • 1322
                              Thanks Steve, I was aware of that one. I was liking the idea of one that is a bit longer as the 3600 AMMO is a longer can.
