Thrust bearing install
  • Geeves
    • 69
    Update on 07-18-08
    Link to Geeves step by step thrust bearing install, take it or leave it
    I tried to intall a thrust bearing on my stock sv brushless. Then motor has too much shaft what can i do? If i cut it do I need to put another keyway in the motor shaft. How perfect of a cut do i need can i just use a dremmel?
    Thanks
  • JimClark
    • 5913
    use extra washers to shim it out
    Billy Graham
    • G Doggett
      • 477
      You can shorten the shaft and extend the flat with a Dremmel quite easily, just make sure you don't get any filings in the motor, but you could just add a second thrust bearing instead.
      Graham.
      • SweetAccord
        Speed Passion
        • 1322
        Both ways would work, but it would be ideal to shorten the shaft and re-key.
        Now, since you have the ability to shorten the shaft, if you measure carefully you can set the shaft lenght and keyway in such a way that the coupler will have the exact .005" gap and not be able to slide down. This may be hard to do but you can do it, I have. Just take time on the filing of the keyway. Remember the thrust bearing needs to have about a .005" (paper space) play between the motor and the coupler.
        Yes a dremel would work.
        • Eyekandyboats
          • 1935
          cut the shaft
          EYEKANDYGRAPHICS
          www.rclipos.com
          • arisarts
            • Apr 2008
            • 14
            Thanks
            Check what I did.
            • Geeves
              • 69
              Sweet tell me how it works im wondering if it bind.
              • SweetAccord
                Speed Passion
                • 1322
                Make sure that piece that is between the thrust bearing and the coupler stays put with the coupler or it will defeat the purpose/function of the thrust bearing.
                Let us know how it works!
                • Daveo
                  • Jul 2007
                  • 34
                  well I will never know if I don't ask. What purpose does the bearing serve on the motor shaft? The shaft already has a bearing where it exits the motor can. Isn't that enough?
                  • Geeves
                    • 69
                    Basically its reduces the load on the motor, causing less heat and ?longer life?
                    Some people argue this because electric motors have come a long way from the 1st rc boats. But for $7.00 and a few nights of screwing around with the sv what harm could come of it.
                    Link to great info on thrust bearings
                    • SweetAccord
                      Speed Passion
                      • 1322
                      Search the OSE thread, put in "Thrust Bearing"
                      http://forums.offshoreelectrics.com/search.php
                      • Geeves
                        • 69
                        • SweetAccord
                          Speed Passion
                          • 1322
                          There you go!
