still slow sv27
  • rainman
    • Nov 2007
    • 2
    still slow sv27
    I have upgraded my sv a few times and now need advice I have a castle 120 esc and need a motor that will make it fly looking for 50 to 60 rang can that be done with the speed controller I have? What prop should I run I am run.2 2s lipos, runs smooth just cant get speed there.
  • Mich. Maniac
    • 1456
    what motor are you using now? To get those speeds your gonna hafta have handling "running a little wet", I would say there is no other than a neu motor for what your looking for and prolly upgrading to a hydra 240A esc. Your looking at dropping another 5-6 hundred to get that fast. Plus props and prolly gonna need some larger batts if needed. Or I have seen in another post if your looking for a SAW setup running a 5000kv neu motor and hydra 240 on 2s lipo. ALL that money for a 100.00 hull? Wow, according to many here the esc you have with feigao or neu and a k48 prop should get you nearly 50mph. That is alot to handle with this hull. good luck and PLEASE share some vid if you get into the 50's
