Info on hop-ups for SV27
  • trax2004
    • 1
    Hi all! My name is Lasse, i am from Sweden.
    I´m on my way buying 2 used SV27 and whant to know what the best upgrades are? From prop to blueprinting the hull. I´ll go LiPo and race in a class up to 15v.
    Thanks in advance for your help!
  • 62 bugzilla
    • Mar 2008
    • 341
    sv upgrades
    Lots of possibilitys. You can scuff the bottom with a scotch brite pad, as far as prop goes it seems like the x642 for a metal prop and a cf 45 for carbon, cooling changes you can either enlarge the hole in your rudder or ad a pick up tube near your trim tab with some brass on a bracket then also drill out your speedo inlets to a little bigger size but don't go crazy and you can also upgrade the size tubing to the one sold on ose, (all parts are sold here and steve is great ) ose also has a motor cooler that makes a big difference than stock .Water proofing the boat should also be done but if it's a used boat it's probobly done. If you want to change motor and esc thats a whole other story. Do alot of searches in this section and you'll have all the info you could want.
    SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
