SV strut bushing
  • Mich. Maniac
    • 1456
    SV strut bushing
    I grease and or oil my prop shafts and flex cable after every run or day of running but am noticing a good amount of slop in the strut. Has anyone noticed the bushing going bad or is this something you should change once in a while? I would say holding boat and prop nut it moves about almost 1/16". Should I change bushing?
  • ice329
    • 797
    You need to change them every once in a while. I had ordered some better ones from OSE, the first bunch were excellent, however the last few I got did not fit right. There better and the price is better, however not sure why the last batch didnt fit right. G/L
    There on this page http://www.offshoreelectrics.com/products.php?cat=76
    • Mich. Maniac
      • 1456
      this one is for the sv strut. Do you think it would be safer to go this route rather than the one you show link for? You would think they would be the same. thanks for the help!
      http://www.offshoreelectrics.com/pro...od=dh-aqub7884
      • ice329
        • 797
        Ask Steve which is the right one from the link I posted. There nicer as long as you get the right ones. Like I posted I got one bunch excellent one bunch seemed to big. I am not sure which ones are right but it is one of them. Ask Steve first.
        • JimClark
          • 5913
          could you swap it out for a bearing from boca bearings?
          Billy Graham
          • Mich. Maniac
            • 1456
            Not sure but if so that would be the way to go. I have some with teflon bushings and they seem better but, honestly not near as smooth as the stinger struts Steven sells. I was thinking of up-grading to one of those but then Im into new holes and such as well.
            • SweetAccord
              Speed Passion
              • 1322
              Bearings, in comparison to a bushing, will cause more resistance spin drag in water anyways, unless they care completely sealed/waterproof then and only then do they have an advantage.
              • JimClark
                • 5913
                they are installed inside either the stuffing tube or the strut hows that going to add drag
                Billy Graham
                • SweetAccord
                  Speed Passion
                  • 1322
                  Water still may enter the strut, not that it would be submerged, just that water may reach the bearing and decay it, hence why I mentioned "unless they are completely sealed/waterproof". As for the bearing to be in the stuffing, well that would be interesting setup to see how that would be setup on a SV27. Any pics please? I'm intrigued.
                  • JimClark
                    • 5913
                    never seen any problem in any hydro I have ever run and I would sure prefer less friction in my system to worrying about a little bit if water
                    Billy Graham
                    • Mich. Maniac
                      • 1456
                      all great points guys but keep in mind I was strictly speaking of the sv strut brass bushing. I doubt I will upgrade the sv to a bearing strut but I was just wondering how quickly even with greasing after every run do they wear out. The bearing setup has always been the way I thought they should be setup. I would just like to see a good hardened stainless bearing. Of course it would not be a cheap setup if that were the case.
                      • SweetAccord
                        Speed Passion
                        • 1322
                        Correct Mich. Manic since this is a SV forum? That is the only boat I have and reference here anyways.
                        My initial frame of thought was from an article that I read somewhere in RC Boat Magazine where it was stated that a bearing would not spin as freely compared to a bushing if submerged, can rust and or cause drag if not taken care of (hence again why I mentioned sealed/waterproof)?
                        I'm not sure what type of drive system was being referenced or such in the article?
                        Even so, like I mentioned, I would like to see a bearing setup with the SV hardware and what all the labor would be and what are all the part numbers to pull that off, it would be interesting. I wonder if anyone has done that.
                        • SweetAccord
                          Speed Passion
                          • 1322
                          Ok, Mr. Jim Clark, here is my bearing answer to clarify to you why I said what I said. I made my statement about the bearing according what I read and what was stated from the Hot Tips and Techniques from the Experts of Radio Control Boat, How To's magazine from the publishers Radio Control Boat Modeler.
                          There is an article by John Gill named "Fast Electrics on a Budget" page 23. Gill was stating some tips in general. Quote "Next check your bearing. Does everything turn freely? I've found that Oilite bushing work very well under water. Although ball bearings are best above water, they seem to "load up" under water, i.e. it takes more power to turn them."
                          That is where my statement is from. Now, what kind of drive system was being referred to is not stated, so I was referring what was stated already in general. I guess if you really would like to know exactly what he was stating and how it's being utilized, I'm sure you can contact him if he's still around?
                          Peace~
                          • Mich. Maniac
                            • 1456
                            UM anyways once I install a new bushing in strut how much slop should there be? I havent paid it much attention on other sv's ive had. so what Im asking is hold the boat in one hand and prop shaft nut in other and move it up and down. Should there be any at all? thanks
                            • bonewar
                              • 587
                              hi mike my advise to you is that there should be very little play in the sharft,replace the brass brushing as soon as you notice movement,i have 5 sv27 an all of them have had trouble with the brushings,so ive change 3 of them for the mtc stinger($127)i no this is a little expensive for the strut but trust me you will have no more trouble. i think the original brushess are only design for low speeds , all of my sv's run lipos , so all of the boats are well over there designed speed, hence the problem. the above stingers come from mhzusa rc boats, go have a look you wont be disappointed.
                              SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
