lipo on sv
I got the DPR setup and tested. I just have to switch a couple wires due to the fact im a retard. Seems I cant follow a wiring diagram if my work is facing the opsosite direction...duuu. I'll get it finished and velcrowed in tomorrow night.
Look at the FMA cellpro 4s Lipo charger/ balancer. Price is right at $64.95 for the 3 amp model and $74.95 for the 4 amp model here:
http://www.fmadirect.com/products.htm?cat=45&nid=4
It charges and balances each cell of my Battlepack 3600 mAh 12/16C packs in less than an hour. Each cell is 4.2volts after balancing. I have 2ea of the 3 amp models and they also sell a 4 amp model.
The cellpro to Thunder Power/Polyquest adapter for $9.95 is what you need for the Battlepack 3600 because it comes with a Polyquest style plug.
Now if I can get rid of my motor stuttering I will really like these batteries. Top speed using the 7.4 volt 3600 connected in series is 39.8 on a M-445 prop and 40.6mph using 2ea per side 7.4 volt paralleled giving 7200 mAh and then connected in series using the existing Deans connectors giving 14.8 nominal voltage.
Espirit models sells a Deans paralled plug for $9.00 each here:
Pic included and two are required.Attached Files
. I will from now on.
