flex cables and shafts Quick Question.
  • fastbaltek
    • 331
    does the aqua craft vegas flex cable and prop shaft fit the sv27? i need the smaller prop shaft (1/8") instead of the 3/16" shaft. i understand the cables are the same (.150) which is what i need. im just worried it wont fit in the strut of the sv27.
  • Mich. Maniac
    • 1456
    It will fit in there however you will not want to use it because of the different size. stock sv uses stuff tube as its bushing and you will need to go another route to suit your needs. why the change anyway. just for props?
    • fastbaltek
      • 331
      yeah, y535.
      i have a strut bushing in mine... i was thinking that if the propshaft was just a 3/16" lathed down to 1/8" then id be fine. does anyone know if that is true?
