Not Looking Good
  • Mich. Maniac
    • 1384
    OR... They could take it off the market and go back to their overbuilt, slow, heavy. plastic boats that are fun for about 10 minutes and You guys wouldnt have to worry about it anymore. Jeez take it easy guys. we are here to help eachother with advise and tips. NOT scare new people away. Maybe its just the weather. everyone cooped up inside but just too much negativity for such a nice product that is just breaking ground to whats to come.
    • SJFE
      • 4735
      My brothers SV had a problem like this. It looks like the tube rolled over to the right before the epoxy ot glue set. He is pulling it for a reset this weekend.
      • Fast Guy
        • 135
        Originally posted by Dale Koblitz View Post
        One last thing, when I arm my radio it makes like a 2 tone beep instead of single beeps? When you guys arm your esc does it sound like 2 beeps togeather or is it clearly a single beep? It does arm it just doesn't sound like a single beep like the manual says? Then since the water is frozen here I put it in the bathtub to test it out and throttle it but if I go over 3/4 throttle it beeps and then shuts off or something? It could be my cheap venom batterys I have in it till I get my lipo's. I would just send it back but I didn't notice half this stuff till after I sealed up all the wood and put a thin layer of glass resign on the floor to strengthen it up. The worst part is I can't test it till spring after the warrenty is up.
        This happened to me also. The brake function of the ESC has been activated. AquaCraft doesn't mention this in the manual as this is an aircraft function of the ESC. To turn the brake function off follow the instructions below. Throttle stick is the same as throttle trigger on your remote.
        BRAKE FUNCTION: The factory default brake setting is “off”.
        Skip to the “ESC OPERATION” section below if you want to
        keep this setting. To turn the brake “on”:
        1. Move the throttle stick to full throttle, turn on the transmitter
        and connect the battery to the ESC.
        2. After 5 seconds the motor will beep twice.
        3. Move the throttle stick to the off position (towards you). The
        4. Again move the throttle stick to full power. The motor will
        beep twice to confirm the brake is now “on”.
        5. Move the throttle stick back to off. The motor will now beep
        four times indicating the motor is “armed”.
        To turn the brake off, repeat the above process. This time the
        motor will only beep once with each stick movement, but will
        beep four times again at the end to indicate the ESC is armed.
        Once the brake is set, it does not require resetting after the
        ESC has been switched off.
        ESC OPERATION
        1. Turn the transmitter’s power on.
        2. Move the throttle stick to the off or brake position (towards you).
        3. Connect the battery to the ESC. The motor will beep to
        indicate the brake setting (once for off, twice for on).
        • motoxbob11
          • May 2007
          • 190
          Oh yea I'm happy overall it was worth the money but a kit would be a great learning tool for a newcomer. There doesn't seem to be anyone who sells a kit and it makes it intimidating to search for a hull and hardware and everything else when you are new to the gobby.
          We ARE here to help and I'll help by saying when you order an SV, order an OSE flex shaft at the same time. You won't be sorry.
          • Dale Koblitz
            • 185
            ESC OPERATION
            Thank you so much! I bet this happened when I was trying to arm my JR radio system. It would have been nice for aquacraft to have put this in the manual. I'm going to try to set it back right now. I'll let you know if it works. I posted this over in RCU and everyone thought I was crazy or something. Thanks again for the much appreciated help.
            Peace,
            Yes, it worked just like you said. Did this happen to you, how did you know about this? This saved me some annoying phone time with customer service. I still have a problem with it stopping if I give it over half throttle quick though? All I have right now is some cheap venom batteries that I rebuilt sxs with deans: bars, noodle, and connectors. But never the less they are junk batteries and they have been overheated and hissed at me once or twice while running them in my truck with a mamba max 5700 system trying to pull 100 amps from them. One peaks at like 9.6 and the other at like 8. something but I don't know about them. I am going to get a couple 2s 5000 lipo's and a low-volt cut-off before spring. I have a couple maxamps 3s 5000's but I think I would fry the esc with those. Someone on youtube told me they run a 2s along with a 3s for a total of 5s and the boat fly's. I will probably try this. My stuff tube is only slightly out of allignment with the coupler but since I allready put a layer of apoxy on the floor and wood to stiffen it up it would be vary hard to move it now. It's only like maybe 1/16 off to the port side. Do you guys think this is a lowvolt cut-off because of the weak batterys causing it to trip when I gun it while holding the boat? It seams like if I hold the back of the boat up so the prop pierces the surface it doesn't seem to trip it. Well I didn't get all the way to full throttle because I didn't whant to soak the bathroom but it seemed better. So I'm thinking maybe between the crap batterys and the added resistance of holding the boat in place it's causing low-volt or thermal cut-off? Anyone else have any thoughts on this? I'm afraid to try it out of water because I've heard BL motors shouldn't be ran w/o any resistance even though I've had my car's wheels spinning full throttle without a load many times showing off the way the wheels expand. I have ran the boat out of the water with little bursts of throttle for like a secong but I don't think I ever gave it WOT out of the water. Is there any way I can test to see if it's the batterys? I couldn't run 1 or 2 of those 3s 5000's could I? By the time the water thaws out this spring the warrenty will be expired so I would like to make sure it's not the esc? Could it be the added resistance of the missallignment of the stuff tube? Sorry I tend to ramble on but I whant to describe what's going on the best I can while I got someones attention.
            Thank's
            Dale "Scott" Koblitz
            Scott
            • Fast Guy
              • 135
              Peace,
              Thank's
              Scott
              If your batteries are weak then you are most likely hitting the low voltage cutoff under heavy load. You could try one 3s lipo but not two. We have 2 SV's. The stuffing tube was misaligned on one and OK on the other. It came loose easily and I epoxied it in the correct position. This is a common complaint.
              • Dale Koblitz
                • 185
                Well as far as the tube goes it's barely out of allignment and it's definately not going to be easy to realign it since the entire floor, all the wood, and yes the stuffing tube has a coat of fiberglass resign on it. I thought it was alligned perfectly when I did that but when I whent to put the flex shaft back in I realized it's not perfect. Now It's going to be very hard to move it or replace it if ever needed. I'm sure it's possible but I'm not going to mess with it unless it causes extra heat or binding. Could I run 1 of those 3s lipo's and 1 ni/mh pack just to test the cut-off theory or should I just put a piece of wire accross the extra connector to finish the circuit while running 1 lipo?
                • motoxbob11
                  • May 2007
                  • 190
                  Originally posted by Rex R View Post
                  we've seen worse... while you 'wait' is a good time to presure test your cooling system and correct any leaks.
                  When I get done rebuilding it I would love to do a pressure test but I don't know how! What method do you use to test it? I can just see the thing filling up with water in the first minute of running due to a leak.
                  • Rex R
                    • 992
                    easy way... take the top off the radio box(so you can follow the cooling lines),get a turkey baster and connect it to the line from the rudder fill the baster w/ water, give it a gentle squeeze to fill the system. if there are no fountains or other leaks... move on to step 2, put a finger over the outlet and gently apply presure(don't need a lot of water presure) the main areas to check; the brass fittings for the esc cooler and the water jacket on the motor.
                    • motoxbob11
                      • May 2007
                      • 190
                      Thats a great idea it will give me a lot of peace of mind on the first run. (Which will be a long time from now unfortunately. It's winter in the Sierras also.)
                      • Bill-SOCAL
                        • 1406
                        I use a hand crank fuel pump that I had laying around. Crank slowly at first and then really stress the system turning it fast!!
                        Don't get me started
                        • Dale Koblitz
                          • 185
                          • offshore1
                            • 7
                            The ESC cut-out you are experiencing may be from holding the boat in place while pulling the throttle. The extra load on the motor from shoving all that water could be something like using a prop that is way to aggressive.
                            That is just a thought. The only way to know for sure is to run the boat in open water. I hope all turns out well for you. I am curious to know what happens.
                            • Dale Koblitz
                              • 185
                              That was exactly my thought and it is partially that but the batterys I was using are the real issue because I ran it on 1 3s lipo which is less volts then the 2 ni/mh's I was running and it has more power and doesn't cut-off. So I just need some new batteries. I'm ordering some 2s 5000 20c's then I can run 4s 5000hv 20c or 5s 5000hv 20c's with one of my 3s's I allready have! I bet I'll be getting close to 50 with that 2p5s set-up!
