Turbo Transmission?
  • showstoppercat
    • May 2007
    • 95
    Turbo Transmission?
    Came across the item at FINEDESIGN -http://www.funrcboats.com/ProductInfo.aspx?productid=21FDMTT
    and FULLERS FAST ELECTRICS -
    - They call a Turbo Trans - My understanding is that it increase the torque and therefore the speed of a stock motor allowing the boat to run with bigger props and offcourse travel Fatser!!!
    Has any used this product in any boat?
    and would it work in a Supervee?
    Can any one assist me with this thought?
  • Steven Vaccaro
    Administrator
    • 8932
    Years ago when batteries and motors where less powerful, it was a needed item in most boats. Today its not as widely used unless you want to switch gear ratios for longer runtime with less speed or shorter runtimes with more speed. But that can be done to a lesser extend by changing prop sizes.
    Steven Vaccaro
    • Steven Vaccaro
      Administrator
      • 8932
      Years ago when batteries and motors where less powerful, it was a needed item in most boats. Today its not as widely used unless you want to switch gear ratios for longer runtime with less speed or shorter runtimes with more speed. But that can be done by changing prop sizes.
      Steven Vaccaro
      • showstoppercat
        • May 2007
        • 95
        Thanks for you promp reply Steve but if this is old technology - why is it a standard fix in OSE toysport jolly cat
        • showstoppercat
          • May 2007
          • 95
          My bad i thought i saw a pic with it fitted in a jollycat - so you wouldnt gain with fitted in a sV27?
          • Steven Vaccaro
            Administrator
            • 8932
            Its not old tech, its just imo its really not needed with most of the high power bl motors out there. It works quite good in lots of setups where the motor is undersized a bit. Or if you have a motor with low rpm, it can be used in overdrive to bring the rpms at the prop up.
            Steven Vaccaro
            • SJFE
              • 4867
              Where did you see a jolly cat with a trans????? I am also interested where you read it wad a standerd 'fix' for that hull?
              Just wondering
              Tom
