trouble with futaba 2PL 2.4GHz Radio System
  • Jblommaert86
    • Dec 2010
    • 10
    So I just got my new futaba 2PL 2.4GHz Radio System today for sv27 for some reason i have to hold the trigger back so the motor doesnt go but if the trigger goes to neutral position the motor goes to full throttle. Im using the stock setup. Any help to fix this would be great
  • icelert
    • Dec 2007
    • 103
    Try reversing the throttle setting (REV-CH2).
    • Jblommaert86
      • Dec 2010
      • 10
      i tried rev ch2 but then its opposite i have to hold the trigger all the way forward to make the motor from not going
      • NativePaul
        Greased Weasel
        • 2770
        Now you have the throttle going the right way (reversed) try recalibrating the throttle end points on the ESC, consult your ESC manual to find how to do this, often but not always its powering up with full throttle for 2 secs going to full brake for 2 secs then neutral, if recalibrating the throttle doesn't work you have an airplane only ESC and a car radio and need a Pixtix (sp) to sort it out.
        • marko500
          • 862
          -Reverse throttle
          -Set throttle trim to 100 reverse
          -Set EPA to full both directions
          -Arm ESC like you did with stock radio
          -This is what I had to set my Futaba 3PM at to get the SV ESC to work.
          Mark
          • Jblommaert86
            • Dec 2010
            • 10
            good info ill have to try this thank you and thank you everyone who's been trying to help me
