Futaba 3PM FM
  • SJFE
    • 4867
    Futaba 3PM FM
    Any one have the setup for this radio with the stock AC esc?? We are having a fit trying to get the esc armed.
    Thanks Guys,
    Tom & Josh
  • Bill-SOCAL
    • 1409
    I have the FASST version of the radio. To get the ESC to arm you need to do 3 things.
    1 - Make sure that the throttle channel is set to "REV"
    2 - make sure that the throttle trim is at full low. Keep pressing it until it beeps steady.
    3 - the sub-trim on the throttle channel needs to be changed. Mine is set to +71
    Then it works great. Turn on the TX, connect the battery. Listen for 1 beep.
    Hold trigger to full throttle
    Listen for another beep
    Release trigger and get a short series of beeps.
    You are now armed and ready to go.
    Don't get me started
    • SJFE
      • 4867
      Many thanks my good man :D.
      • Rex R
        • 1007
        or just use throttle trim(w/ thottle rev on) -26-28
        • Bill-SOCAL
          • 1409
          All Futaba radios need the throttle reversed. First thing you do.
          Here's why I use full low throttle and then set the arm point with the sub trim.
          WIth this set up I do not have to worry about if I have moved the throttle trim. I run it all the way down and then set the sub trim. That way I am less likely to make a change due to bumbling around with the TX.
          On one boat I did set the throttle trim to zero, but I still use the sub trim, because again, I cannot "accidentally" bump the sub trim.
          Works for me.
          Last edited by Bill-SOCAL; 12-04-2007, 06:38 PM. Reason: Pesky tie-poes and added more explanation
            Nice to know now I bought a Pi-Stix.
            I will try this with my Hextronic 120's thanks guys!!!:D
            • toddilgen
              • 86
              so bill when you say full low you mean zero on throttle trim in step 2 then go into subtrim and apply more forward trim? or more brake?
              ALL OUT POND BASHING MANIAC!!!:D
