new SuperVee Owner need little advice
  • x2beach
    • 37
    I just received mine last night from Tower. I didnt have and 2cell lipos so I installed a 4 cell 5000 25c Lipo I installed it in the middle of the boat. and wow Does it run very very good. Ive been reading and not sure what Prop to get and where can I get a better prop?
    Does anyone have and pics of what the did to seal it so no water get inside anymore?
    thanks!
  • Avanti
    • 1298
    remove all the hardware off the tromsom and make the adjustments needed then reinstall using silicone, this should fix any would be leaks. Start out with a grimracer 42x55 2 blade prop, the boat will come up on plane faster and run well. Search around the boards and you will find a lot of good advice.
    The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
    • x2beach
      • 37
      I just order a new prop from the supervee page on this site and the better cooling jacket.
      when you say reinstall using silicone do you have any pics? I am a newb to boats
      thanks
      • ice329
        • 797
        The prop steve has on the superV page is really to much. A CF45 is a better choice, a X642 is a very good choice also. There are many posts on how to get your boat ready for the water. G/L
        • Avanti
          • 1298
          You really can't see anything different in the pic, but I will send it to you if you want it, PM me.
          Before replacing your hardware on the boat put a thin coat of clear silicone on the part that will come in contacted with the transom also a little on the screw threads that will be in the hole. Take your time and clean up after each part is replaced and you will have a neat leak free boat.
          • x2beach
            • 37
            What is the Transcom? I am sorry for the newb questions
            • Avanti
              • 1298
              Front of boat = bow
              Back or boat = stern
              the very back of the boat where all the hardware is mounted is the transom
              left = port
              right = starboard
              the ribs on the bottom of the boat are called lifting strakes
              the outsides of the bottom are called chines
              that should do it
              • Bill-SOCAL
                • 1409
                Some refinements from my days in the Navy
                Bow = Pointy end
                Stern = Wide flat end
                Transom = the cliff at the stern of the boat
                port and starboard are relative to facing towards the pointy end
                Don't get me started
                • ice329
                  • 797
                  Front, back, left side, right side, top, and bottom. Makes it easy to.
                  • Bill-SOCAL
                    • 1409
                    We used to say "pointy end" and "wide end" along with "upstairs" & "downstairs" to annoy the lifers when I was in the Navy!!
                    • Avanti
                      • 1298
                      that's funny
                      Bow = Pointy end
