motor/esc question
  • russ722
    • 102
    motor/esc question
    currently i have 2 supervee motors (no both arent installed in my supervee :) ) with the stock esc whats the best motor i can get for the supervee? are the blackjack 26 motors better or the same/would it work with my stock esc?
    Insane Gen II Cat
  • Diesel6401
    Memento Vivere
    • 4391
    Do you want to use the stock esc?
    If yes then the BJ motor is a little less KV, but a better motor over the blue can sv motor. You could also get the new SV27R 6 pole 1800kv motor, which would run a lot better over the blue can sv motor. Both motors can use the stock esc and.
    If you want a complete different setup motor/esc. Grab ul-1 power.
    Are you using lipos?
    - Diesel's Youtube
    - Diesel's Fleet
    • russ722
      • 102
      hi, thanks for the reply . im going to using the stock esc for now just was wondering what my motor options are on it. yea im starting out with X2 3700 2s lipos that came with the boat .
      Insane Gen II Cat
      • Diesel6401
        Memento Vivere
        • 4391
        3700mah, what "c" rating? That's pretty low mah... Running 2 2s and the stock esc you could run the new sv27r motor, you might not see a huge jump in mph but it is a lot more efficient, you could run the ammo 36-50 2300kv motor, that would get you into the mid 40s (personally Im not a huge fan of that motor but that JMO). You could run a BJ motor and swing a HUGE prop. With that stock motor and esc you can get very high 30s i.e 39mph with a 42x55 prop, you may even hit 40 stock. Make sure you use a lipo shield on that esc. IMO ul1 power is hands down the best for boat (check my vid in my signature).
        - Diesel's Youtube
        - Diesel's Fleet
        • russ722
          • 102
          the batteries are 20c ,yea i know there on the low side but they came with boat :) eventually im going ul-1 power power on this one . thanks for all the info i appreciate it.
          Insane Gen II Cat
          • Diesel6401
            Memento Vivere
            • 4391
            Yea those batts are just barley putting out enough amps for that setup. I would look at buying new batts before a new motor! Mah rating means A LOT MORE then just run time! That mah and c rating will determine how many amps your batts can supply to your setup. Invest in some different higher mah packs. I use alot of 4000 & 5000 40c packs
            - Diesel's Youtube
            - Diesel's Fleet
            • Krowbar69
              • 237
              What about Outrunners Diesel??? 2200 Kv ones??? lol....
              • Diesel6401
                Memento Vivere
                • 4391
                The genius on your plan lol
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4391
                  I have a BJ motor with 3 runs on it. Would be great on 4 or 5s with a 45mm prop. I'm thinking of selling it, so if you want it let me know. http://www.offshoreelectrics.com/pro...rod=dh-prb3310
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • russ722
                    • 102
                    thanks for the offer but im gonna wait on it. like you said i need some better batteries and a lipo charger more right now.
                    Insane Gen II Cat
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      Good move!
                      - Diesel's Youtube
                      - Diesel's Fleet
