I just got back from running my boat today, and noticed when the boat is on plane and running full speed, the water seems to slow or stop coming out of the water outlet... When i slow down then water comes out great... Is that normal????
I recently had a bad experience with my SV cooling. Smoked my motor in the end, cause my rudder water pickup was clogged. Make sure that it is clear by blowing into the top. I just got the transom water pickup and have yet to try it out, but it looks promising. Also, I had no idea that water wasn't coming out, since sometimes it looks like it is from the side.
Ya it's the stock rudder one.. i can see water coming out at lower speeds, but not at top speed.. maybe the water inlet is lifting out of the water at full speed.. I have a UL-1 motor so it really cooks...
I have the CF 42... and that boat really cooks.. can't wait to get a metal prop..
i was using an x440/2 which got it out of the water real fast and seemed a little faster but made the boat more unstable for some reason. when i run the three blade prop it runs real smooth. i hear the 40/52 i real close to the x440/3 but i would like to get the x440/3 when theyre back in stock. i think it may be a bit faster. also someone told me to try an x642... but i dunno bout that. thats alot of pitch for a high rpm motor. prolly a bad idea
X642 and Grim 42X55 were recommended to me by Diesel.... but in the mean time i got the CF-42 cause you don't have to balance and it's cheap!!! lol.. I need to work on the CG and the trim tabs on my boat still. It's own wake almost makes it flip.. In fact it did flip it...
Yepp, everyone including Diesel, has recommended the 42x55 prop. I've been running the 40x52 that dana has. You should definitely order the 42x55 from Egneg, he did a great job on mine!
