got a few questions .
  • russ722
    • 102
    Hi, i just picked up a supervee last night with 2 of these lipos
    will these work ok with the supervee? im a total newbie to brushless systems so i have no clue . also i will be looking for a charger as well and was recomended this one http://www.valuehobby.com/product_de...13&item_id=110 what do you guys think ?
    Insane Gen II Cat
  • dana
    • Mar 2010
    • 3660
    yes but you can only run one at a time or run them parallel, but i dont know if you would be able to fit two 4s packs in an sv. i run two 2s packs series like most people do im sure.
    • russ722
      • 102
      thanks for the quick reply , about what speed range would i see running it with one battery on stock electronics?
      Insane Gen II Cat
      • dana
        • Mar 2010
        • 3660
        probly around 35ish to low 40's maybe. not 100% on that. you would be running 4s, which is the same as my two 2s packs series (makes 4s).
        • russ722
          • 102
          ok thanks for the info , im assuming the 4s are a larger sized battery pack then the 2s? are these stock motors any good ? ill have a extra one also already thinking of looking for another hull to throw it into :)
          Insane Gen II Cat
          • dana
            • Mar 2010
            • 3660
            yes the 4s is just a larger pack and yeah the stock motor esc is a good combo. reliable setup. i use a ul-1 motor esc in my sv, but both are great
            • russ722
              • 102
              ok thanks alot for the info i appreciate it.
              Insane Gen II Cat
              • russ722
                • 102
                just got the boat today and i noticed the batteries arent marked for 2s or anything? how will i know what they are?
                Insane Gen II Cat
                • dana
                  • Mar 2010
                  • 3660
                  you said you bought 4s didnt you? you can plug them into your balancer and that should tell you
                  • russ722
                    • 102
                    yea i thought i seen in the pic a check next to 4s but it muct have been a glare or something . there is no marks on the battery on what they are . they look just like these to a t except the amount of s http://www.hobbycity.com/hobbycity/s...idproduct=7296
                    Insane Gen II Cat
                    • dana
                      • Mar 2010
                      • 3660
                      well try plugging into the balancer. it will tell you. or the dimensions are posted on the website. measure yours.... im sure theyre 4s if that is what you ordered
                      • russ722
                        • 102
                        thanks for the info ill order a charger and find out that way . the batteries where included with the supervee .
                        Insane Gen II Cat
                        • dana
                          • Mar 2010
                          • 3660
                          ahhh... wel if they were included with the supervee my guess is they are 2s packs. because they sv is built to run on two 2s packs
                          • russ722
                            • 102
                            might be there are both Velcroed in the hull
                            Insane Gen II Cat
                            • russ722
                              • 102
                              ok looking at these three diff packs mine looks more like the first one. a single /slim battery pack
                              http://www.hobbyking.com/hobbycity/s...idProduct=7651
                              Insane Gen II Cat
