Question re: Aquastar 90 amp ESC
  • johnmaclean
    • 259
    Just finished setting this up in my sv27 and programming it using the pistol. It took a little while to interpret the less than ideal instructions posted online at HK.
    I had initially left all of the settings at factory default but have since questioned leaving the factory default lvc. It is set to 6.0 volts which I am assuming is based on a single 2s lipo.
    Since I am running 2, 2s packs in series it seems to me that the 6 volt cut off would be far too low for the combined packs and I would end up over dischargng them since their combined nominal voltage would be 14.8 volts. I'd probably select a 12 volt cut off for the packs since a 6 volt cutoff would pretty much destroy them.
    Anyone familiar enough with setting up these ESC's to comment? I want to make sure I have it right before I run it this weekend.
    Thanks for reading this.
    A dream not pursued is not worth holding.
    Aquacraft SV27 x 4, Proboat Mini-V, Redtail Kneeler Hydro, JAE21, ML GP335
  • Diesel6401
    Memento Vivere
    • 4391
    You are correct, the 6v is for 2s or 3.0v per cell which is way to low anyway. I use the auto function on my aquastar, but I also ALWAYS time my runs so the lvc shouldnt ever kick in. I have only hit it once on many many runs.
    - Diesel's Youtube
    - Diesel's Fleet
    • johnmaclean
      • 259
      Thanx, Diesel. I appreciate the response. Yep. . . I plan on timing my runs but wanted to make sure that if in the excitement of the thing I forgot to check, I'm not gonna turn the packs into boat anchors.
      Regards,
      John
