Everybody seems to remove there radio box to make more room & for easy access to the batteries , well here is an easy mod using the SV radio box , all i did was cut it down into a tray & left the servo mount intact ....& moved the ESC to in front of the motor... its a neat conversion i think...
Radio Box Mod
Cheers , not a big fan of balloons ,you have to change them all the time due to condensation build up, i cover my recivers in Vaseline its works really well , never had one fail since i have been doing it ....plus i use a really good hatch tapeOriginally posted by forescott View PostI think thats a great idea. I would put a balloon on that receiver though. The tactic doesnt fare well with any water contact.
JasonUL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
That's funny, I just did the same thing Monday night. I was just going to post pics asking for advice but now I can use yours. I can't seem to fit the esc, Novac lipo cut-off, and airtronics micro reciever on there so it looks nice and the cooling tubes aren't kinked? I think in the near future I'm going to make a plexiglass plate with an aluminum servo mount from offshore but I'm going to a camp groung tomorrow for a family function and want to bring my boats and cars. The main problem with this set-up is the servo mount takes up to much room. If I had one of those small aluminum ones I could move it over and lay the esc flat. I can't do that now though?
here is mine, did this last year :)Attached Files2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
scoota, Can I see some pics of how you mounted your esc? jlr3rd1, I tried putting mine next to the servo like yours but I'm just not happy with how it fits with all the cooling tubes and LV cutoff. It looks like you have a diff esc?Originally posted by scoota View PostEverybody seems to remove there radio box to make more room & for easy access to the batteries , well here is an easy mod using the SV radio box , all i did was cut it down into a tray & left the servo mount intact ....& moved the ESC to in front of the motor... its a neat conversion i think...
I glued a small piece plywood the size of the ESC across the bottom of the hull in front of the motor, with some velcro on it which i sit esc on top.....im running the UL1 esc & motor...UL1- 1515 castle/neu / 240 swordfish
I like the spot up there for the esc.
My hull was always stuffed with foam noodle.
I never got the chance to picture my esc up there. LOL
Looks great!
I did the same thing with the radio box.
Old picture though.
Ended up turning into this.
Z
KBB34" Mono - Fast
ToySport Triton- Not as fast
Looks like things are getting a little rusty in there...Originally posted by scoota View PostEverybody seems to remove there radio box to make more room & for easy access to the batteries , well here is an easy mod using the SV radio box , all i did was cut it down into a tray & left the servo mount intact ....& moved the ESC to in front of the motor... its a neat conversion i think...Support US hobby suppliers
