OMG! LiPo's are incredible!
  • ms71171
    • 127
    Just got back from running LiPos for the first time! Turnigy 5000mAh 2S 20C
    Unreal how fast now! And ran for 15 minutes until it got too dark.
    Just a few questions.
    - Motor got pretty hot. I'm running a Grim 42x55 and stock otherwise. I could only keep my finger on it for 1-2 seconds. Maybe need to upgrade my cooling sleeve?
    - Do I need to do anything with my speed controller to set it for LiPo's? I had a long series of beeps when I first turned it on and took some time to get the 4 beeps.
    - I need a LiPo protector I suppose. I ran the cells down to 3.78 or so and they were 4.2 when charged. I know you should not run these below 70%.
    32" Toysport Triton, stepped hull, no flood chamber, 1515 1.5y NEU 1500kv motor, 180a Turnigy SC - running 6S, Aquacraft SV27 - currently running UL1 motor on 4S. Boat has seen 59mph running Feigao 11XL on 6S, 17" Velocity Minicat
  • Diesel6401
    Memento Vivere
    • 4391
    15ms is a LONG time. Cut the run time down to 5-7ms WOT. If you are using the stock sleeve update to better one and open the pickup hole in the rudder with a small rat file. All that should help. Also invest in a digital pocket thermometer and a lipo shield. Your long series of beeps had nothing to do with the lipo's something with your throttle settings was off for a second.
    http://www.offshoreelectrics.com/pro...hld-32&cat=136
    http://www.offshoreelectrics.com/pro...od=dh-DTXP3100 or http://www.harborfreight.com/non-con...ter-93983.html (i use this works great)
    http://www.kintecracing.com/Supervee_27_upgrades.html (scroll down to super cooler, you need the short verison)
    - Diesel's Youtube
    - Diesel's Fleet
    • wizard122
      • 535
      Yes you will need a LVC or you will damage your new batteries. As for things getting hot 15 min run time is very long 5 to 7 min run time is the norm understand that under a load those batteries fell way below 3.7 volts be careful. With the LVC installed you wont get that kind of run time. Is the new prop your running Sharped and Balanced if not you should get it done for sport running I like a X440 motor and ESC run much cooler with that prop. Good Luck
      2 SV 27's and Vac-U-Pickle UL-1 Power
      • ms71171
        • 127
        Oh ok crap. Glad I stopped when I did. The prop is not balanced.
        • jnation89
          • 29
          i agree i just got my lipos in today and woooow
          at first it was too crazy i flipped it and had 2go swimming....but out here in az the water is warm
          but even with the trim tabs turned down still nuts....but i also had a long run time....not 15mins but a good ten...i also have a lvc and nothing got hot at all....wat do you guys think about the m445 prop on it?
          • ms71171
            • 127
            I've never used that prop, but I hit 51 with an x642 running 6S. I learned finally with my SV that getting your COG right is best so you don't have to use your trim tabs.
            • Diesel6401
              Memento Vivere
              • 4391
              45mm prop is big, the stock motor can handle it but be very VERY cautious of the run time and temps. As stated above the 42x55 is the best prop for the SV JMO.
              Watch swimming, im sure someone will chime in and throw a big hissy fit over it. IMO situations vary and people are adults. Smoking kills millions, but people still smoke so whatever...
              - Diesel's Youtube
              - Diesel's Fleet
              • ms71171
                • 127
                Why watch swimming? I had to yesterday lol.
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Many of people of drowned swimming after their boats including a father/son a few months ago. Just be safe.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • jnation89
                    • 29
                    good thing the lake i run in is only about 7ft at the deepest....and today i ran mine for a good ten minutes and everything was cool to the touch....do i just have a lucky boat that runs cool?
                      • 9481
                      I've run upto a 48mm prop and love it on my SV's
                      • ninjaSV27
                        • Jun 2010
                        • 19
                        or you can purchase an inflatable raft at your local sporting good store for less than 75.00. Also yesterday my SV went up in smoke in the inlet. My seaking ESC stop working yesterday so I fitted my SV with the stock ESC 45amp with two 5000mah Turnigy and placed the SV back into the inlet......the SV zipped off at very high speed less than 20 seconds, smoke was comming from my SV. I open the SV and my stock ESC was burned to a crisp. Now I have to check and see if everything is working ..motor, batteries.
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          2 esc burnt that quick. Something is DEF wrong with your setup. Post everything you where using, prop, stock motor or different, what voltage lipos etc maybe we can help.
                          Or buy a PFD if you want to swim.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • ninjaSV27
                            • Jun 2010
                            • 19
                            thanks Diesel,
                            the motor that I was using was the 2300KV Ammco, prop Octura 440, and Lipo turnigy 2C 5000mah at 30c times 2. I have notice that my setup was running hot lately so I am planning to install dual cooling system. The seaking that I was using was the 60amp that stopped working and the stock ESC that was fried was the Aquacraft 45 amp MiMH/NiCD. I'm not sure if I should upgrade to an 120 or 180 seaking ESC or just continue to stay with a 60 or 90 amp seaking ESC?
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              thanks Diesel,
                              The esc 45 or 60 range should work fine with that motor. Their is something else wrong, is your prop properly sharpened and balanced? Ammo motors will heat up quick if you are runing your boat to wet or not properly proped. Proper cooling is a must at all times. Bumping up to a higher esc is a band-aid for a gun shot wound in this situation, you need fix the problem from the source. That ammo should not be burning out a 45 amp especially not a 60amp esc.
                              - Diesel's Youtube
                              - Diesel's Fleet
