Broken prop
  • archuraas769
    • Jun 2010
    • 53
    Broken prop
    Im running 6s lipos in my ammo 1280 mottor with a CF 45mm prop and im not sure how it happend but i broke 1 and a half blades of a 2 bladed prop, my computer wont letme post the pics
  • Diesel6401
    Memento Vivere
    • 4391
    Too much workload for the CF prop to handle. Your going to have to swap to a metal prop or you may keep blowing through plasti ones. Th Octura x445 is similar to the CF45 which you are running now. The pre sharpend & balanced props are outof stock, but here is the raw one which you will have to sharpen and balance yourself.
    http://www.offshoreelectrics.com/pro...?prod=oct-x445
    If you don't want to do it yourself Chuck (Egneg) here on the forum does a GREAT job and is a pleasure to do business with. He will sharped and balance it for you. http://forums.offshoreelectrics.com/...ead.php?t=7367
    - Diesel's Youtube
    - Diesel's Fleet
    • archuraas769
      • Jun 2010
      • 53
      is the 445 the best prop for the ammo 1280? because my cf 45s are sucking alota air
      • Diesel6401
        Memento Vivere
        • 4391
        Not sure what you mean by "sucking a lot of air" cavatating?
        - Diesel's Youtube
        - Diesel's Fleet
        • archuraas769
          • Jun 2010
          • 53
          ya thats what i meant
          • Diesel6401
            Memento Vivere
            • 4391
            Your the only one I have read running a low kv high volt setup in a SV so if it is cavatating alot you may need a bigger prop. I am sure the CF prop was prob flexing some do to the load, but im not sure. Maybe a x447 im really clueless on what will work well with your setup. I would drop what your running now in a bigger hull maybe like a df33 copy, JMO. Maybe a OSE guru can help with that question.
            - Diesel's Youtube
            - Diesel's Fleet
