i put a new water jacket on my motor and a pickup on the hull, then i put a "T" connector in the line and used the stock rudder pickup with the hull pickup, will that be ok or should i leave the rudder pickup off?
cooling jacket
Use one or the other. Not both. Water follows the path of least resistence. If you have a transom or trim tab pickup AND the rudder pickup, there will be hull ride angles (like in a turn) where the hull or trim tab pick up are out of the water. In that condition the water being picked up by the rudder will simply drain out the hull/trim tab pickup and not pass thru the motor/esc. Like I said. Its the shortest path.Originally posted by Driggs View Posti put a new water jacket on my motor and a pickup on the hull, then i put a "T" connector in the line and used the stock rudder pickup with the hull pickup, will that be ok or should i leave the rudder pickup off?
JohnChange is the one Constant
Originally posted by m4a1usr View PostUse one or the other. Not both. Water follows the path of least resistence. If you have a transom or trim tab pickup AND the rudder pickup, there will be hull ride angles (like in a turn) where the hull or trim tab pick up are out of the water. In that condition the water being picked up by the rudder will simply drain out the hull/trim tab pickup and not pass thru the motor/esc. Like I said. Its the shortest path.
John
Use one for the esc and one for the motor. You can then use the T for the outgoing water.
IMPBA 20481S D-12
I use both pick ups and 2 outlets. With a fail safe design. Temps average 100-110 on both the motor and esc with averae speed of approx 45mph top speed was 47.3mph with a garmin gps.
