Removing battery tray - Is there a 'How To' or some tips?
  • ms71171
    • 127
    Going to do this mod this weekend. Just wondering if there is a thread or some tips on doing this. Looks like I will need to use a dremel tool with a disc cutting head, but not sure if there's an easier way.
    Thanks in advance!
    32" Toysport Triton, stepped hull, no flood chamber, 1515 1.5y NEU 1500kv motor, 180a Turnigy SC - running 6S, Aquacraft SV27 - currently running UL1 motor on 4S. Boat has seen 59mph running Feigao 11XL on 6S, 17" Velocity Minicat
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    I scored the wodd pieces with an x-acto then gently pulled them out with a pliers. Then you can smooth out the surface with a dremel or similar.
    • osprey21
      • 723
      Quite a few guys only remove the forward end of the trays and leave the rest in the hull.
      Not mine - but here's a pic.
      • Brushless01
        • Apr 2010
        • 489
        I used a flat blade screw driver they come of easily
        Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
