Sv motor upgrade options ??
  • Brushless01
    • Apr 2010
    • 487
    What would you reccomend ??
    And would a neu castle 1515 fit the mount ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • m4a1usr
    Fast Electric Addict
    • 2032
    Yes a 1515 will fit in the stock mtr mount but its not the right mtr for that hull. Its too big. A 1512 is the recomended hop up mtr for the hull and more then enough to push the hull into unstability. You could get by with a 1509 too as that mtr has more power then the stock one does.
    If you wan to go crazy fast get a 1512 2D. Just make sure you always tape up the hatch because you will end up flipping it when you least expect. But it is fun hauling the mail!
    John
    Change is the one Constant
    • Brushless01
      • Apr 2010
      • 487
      Might try this motor and esc the 2200kv http://www.offshoreelectrics.com/pro...-combo&cat=134 should get 60 mph on a x447
      • wizard122
        • 483
        I've run mine with the Ammo 2300 and got over 50MPH out of it but it was upside down more than not. The SV at over 45mph is a handful to run I put the stock SV motor back in and get 40 MPH all the time with a Grim 42/55 and it runs great. My friend has a UL-1 setup in his and that runs great also. I think that if you really want to go that fast its time for a new boat maybe a DF 33 anyway thats just my 2 cents.
        2 SV 27's and Vac-U-Pickle UL-1 Power
        • BakedMopar
          No Mo Slipah
          • Sep 2009
          • 1679
          I had a Feigao 12l in mines. It was a little quicker than the SV motor and I was still able to use the stock esc.
          • Diesel6401
            Memento Vivere
            • 4203
            Hull is rated at 50mph, anything even close to that is a handfull. Mid 40s is where the boat is happiest IMO...
            - Diesel's Youtube
            - Diesel's Fleet
            • forescott
              Hopelessly Addicted to RC
              • 2686
              A supervee at 60mph is an airplane.
              • Diesel6401
                Memento Vivere
                • 4203
                I wouldn't spend Neu money on a SV, if you want a different motor rock a 12l like baked said or ul-1 power like mine and it will run good. If you wanna run a Neu, buy a DF hull or even a DF copy, JMO....
                - Diesel's Youtube
                - Diesel's Fleet
                • Brushless01
                  • Apr 2010
                  • 487
                  Ive already got one with a ammo 2300 and im shortly getting a erbe so i might try the mamba in a sv
                  • Brushless01
                    • Apr 2010
                    • 487
                    Any more suggestions any welcome
                      • 9479
                      • Brushless01
                        • Apr 2010
                        • 487
                        How about the mmm combo in a delta force 29 with sv hardware
