Ul1 motor and sv esc ??
  • Brushless01
    • Apr 2010
    • 489
    Would this work ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Jeff Wohlt
    • 2740
    Yes but keep prop smaller. The reason is the SV ESC is rated for 45 amps and the motor it comes with is only about 1800 kv. With the UL motor you are stepping up to 2030 KV so more amps on the ESC. Should have no problems...check temps to see where you are after 1 minute of fast running....no dogging it around....just makes it worse....and a bunch of on-offs will heat any ESC up.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • Brushless01
      • Apr 2010
      • 489
      Thanks i ended up going with the stock motor ose had no ul1 motors in stock.
