Has anyone experience ESC issues with the Ammo 36-50-2300kV Brushless In-Runner Electric Motor? I was informed by AquaCraft's technical support that the 2300 Ammo motor is not comparable with the stock ESC. In order to use this motor you will have to upgrade the ESC to the 60amp or risk burning out the speed control. So far I have destroyed two speed controls with the 2300 Ammo motor and stock ESC.
Speed Control issues with Ammo motor
Which ammo motor are you running? The 2600 is not going to work with the stock SV esc, only the 2300 is going to work with the stock sv controller.Originally posted by ninjaSV27 View PostHas anyone experience ESC issues with the Ammo motor? I was informed by AquaCraft's customer support that the Ammo motor is not comparable with the stock ESC. In order to use this motor you will have to upgrade the ESC to the 60amp or risk burning out the speed control. So far I have destroyed two speed controls with the Ammo motor and stock ESC.
What size prop you using? How long are your run times? Over-proped or running to wet and to long will result in the escOriginally posted by ninjaSV27 View Post2300
with that motor.
I've run my SV with that motor and stock ESC and have had no problems. You may have blown a cap so try adding some caps to your ESC Kintec sells them. Also you cant run any prop bigger than a 42mm a 40mm would be better are you still using Deans you should upgrade to 5.5mm at battery and ESC hope this helps. PS make sure its not running wet that will heat things up fast post some photos of your boat so we can help.2 SV 27's and Vac-U-Pickle UL-1 Power
The best prop we found with the ammo 2300 in that size boat with the stock ESC is the X437/3 blade or the X637/2 blade.
A 642 is pretty big for that motor.If all of your wishes are granted, many of your dreams will be destroyed!
