45.6 mph sv27
  • Brushless01
    • Apr 2010
    • 487
    45.6 mph sv27
    Hi guys took my Supervee out today and got her up to 45.6 mph the boat was running beautifauly nice and smooth.
    Setup:
    Grimracer 40x52 3
    Ammo 2300
    UL-1 ESC
    2X Team Orion 2400 rocket packs
    Neutral tabs
    Positive out drive
    Rudder tucked under.
    GPS used was a Garmin forrunner 101
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Brushless01
    • Apr 2010
    • 487
    Is that a good speed ??
    • Diesel6401
      Memento Vivere
      • 4203
      Slightly change your set-up to a grim 42x55 prop and grab some 2s 5000mah 40c lipo's and you should be in the low 50s
      - Diesel's Youtube
      - Diesel's Fleet
      • Brushless01
        • Apr 2010
        • 487
        Hi Diesel I also have some 35c 6400's but it bounces around like mad with them. I probably wont change the prop as its fast enough how it is. And cause ose dont have any 42x55's SAB in stock
        • Diesel6401
          Memento Vivere
          • 4203
          Good luck with your re-build. If you really want that prop Chuck here on the forum can s&b one for you. He does great work.
          The bouncing maybe a CG issue with those bigger batts. Move them forward, to do this remove the battery trays.
          - Diesel's Youtube
          - Diesel's Fleet
          • forescott
            Hopelessly Addicted to RC
            • 2686
            Thats flying for an sv! You really gotta dial in the handling of the sv to get that kinda speed!
            • Diesel6401
              Memento Vivere
              • 4203
              If he had a different motor other than that 2300 he could run that 42x55 with slight negative on the trim tabs and run 47-48 and very stable (see my video), but that ammo motor likes the boat to run neutral or loose, to wet with that motor and temps get hot quick. Like I said with the 42x55 and the ammo 2300 you can break 50 without a doubt (just ask wizard)
              - Diesel's Youtube
              - Diesel's Fleet
              • Brushless01
                • Apr 2010
                • 487
                I already removed the battery trays that was the first mod i did thanks for the recommendations Diesel.
                • forescott
                  • 2686
                  I never did like the ammo 2300 in my sv. I think the ul-1 motor would have been a better choice.
                  • wizard122
                    • 483
                    52.7 mph
                    Like Diesel said I got mine up to 52.7 mph with an Ammo 2300 and a 42/55 Grim prop
                    But I liked it better with a X442 If I ran it for a whole charge the temps were lower
                    and it didn't flip as easy
                    2 SV 27's and Vac-U-Pickle UL-1 Power
                    • Brushless01
                      • Apr 2010
                      • 487
                      Thanks wow wizard that thing flys i gotta got a 42x55 next !!!
                      • wizard122
                        • 483
                        Cool just watch your temps that was a 2min run more than that and things can get hot Impotent upgrades are 5.5mm connectors at battery and 4mm connectors at motor
                        • Brushless01
                          • Apr 2010
                          • 487
                          What was hot motor or esc i have the transom and rudder pick up will it still get to hot ??
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Diesel6401
                              Memento Vivere
                              • 4203
                              I average 100-110 degrees F on my setup after a 3-4 minute run. Keep everything under 130F (playing it safe). I think around 150F - 160F the motors will de-mag, not sure though I did have my traxxas velineon motor up to 180F before by accident and it still runs like a champ.
                              - Diesel's Youtube
                              - Diesel's Fleet
