transom water pickup
  • ggcrna
    • Apr 2010
    • 37
    Contemplating the installation of a water pickup @ the transom. Does anyone have any photos of how they route the tubes. Do you use a Y connection to join the pickup line from the rudder?
    Thanks,
    G
  • badag98
    • 190
    I dont have any pics handy but have a few out in the photo part of site. I used a Y connector to bring both lines together so I could run only one line out.
    • wizard122
      • 483
      Heres my latest set up
      These set up has been working great for me stopped using transom pickup in favor of the rudder after I opened up the hole with a file just works better and no drag.
      2 SV 27's and Vac-U-Pickle UL-1 Power
      • Diesel6401
        Memento Vivere
        • 4203
        Thanks,
        G
        I use 2 outlets so I can monitor both pickups. Rudder pickup exits the right, transom exits the port side (stock), I also did as Wizard did and opened the hole on the rudder with a small file (works way better). I have mine connected in a fail safe manner, meaning both provide cooling to both the esc and the motor so if one should happen to clog the other can still provide suffeciant cooling. I work in aviation and every system has a back-up, so that's how I wired my boat. Temps have yet to be an issue.
        - Diesel's Youtube
        - Diesel's Fleet
        • badag98
          • 190
          Wizzard, I see that you have the cooling motor mount from kin. but are not using it. Is there a reason? I have it as well but I am using it. I feel that water flow slows greatly there and lets temps get up a bit.
          Is this the case and you decided not to use it?
          Thanks
          • ggcrna
            • Apr 2010
            • 37
            Water pickup
            Thanks guys for the awesome photos. They help a lot.
            G
            • wizard122
              • 483
              Side plates
              Yes I felt it was a bit restrictive but I love that mount after I made the side plates it makes it so easy to R&R plus it is stronger and pits less stress on wooden rails
              • badag98
                • 190
                Where can i get a set of side plates? I have striped the screws to the motor and have to remove the whole mount when i change motors next. It is just so tight and hard to get a allen wrench in its hard not to mess something up. It looks like you changes the screws to the mount as well, can you get them out with a small socket or something other than an allen wrench?
                • wizard122
                  • 483
                  I made them myself and i cut the short end of an allen wrench to give me more clearance
                  • wizard122
                    • 483
                    latest set up
                    This is my latest set up
