My SV rebuild
  • bmaxx
    • 27
    My SV rebuild
    I have totally striped down the hull and started to sand in preparation for a small repair and most importantly to get rid of the red. When I started to sand the bottom I noticed a couple of pin holes, and I do not even know where to start to fix. Can some one point me in the right direction... Thanks
  • badag98
    • 206
    I used Z-poxy to repair a large hole in mine and it worked fine so I am sure it will work fine for the small holes as well. I hit the fountain in the middle of my lake and crushed the front of the boat.
    I mixed up some zpoxy and just poured it into the boat and hung it up so the epoxy would get into the holes. I taped it up from the out side to prevent a mess on the out side and it worked pretty good. After it dried a day I repeated it twice to make sure all the holes were plugged.
    Next I sanded the out side and painted!
    • bmaxx
      • 27
      Sounds easy.
      I will update with my progression, and I am sure I will have allot more questions as I go.
      Thanks
      • viper137
        • Apr 2009
        • 5
        I want to do the same. Once cured how hard is zpoxy to sand?
        • badag98
          • 206
          Not too hard, i have one of the little hand sanders and it worked perfect!
          • bmaxx
            • 27
            I finally got a chance to get back to the boat today. I brushed in some Z poxy finishing resin into the holes, and it seems to have done the trick. Now I am starting to get ready to cut the CF pieces, but more ?????? Are you supposed to put a strip of glue where you want to cut? I cut one smaller piece out, and the cf is fraying apart.
            I have tried the search function on how the lay CF but I have been unsuccessful
            • 20psinow
              • Feb 2010
              • 148
              i used painters tape (blue tape light tach) and just layed it where i was going to cut and worked out ok..
              • wizard122
                • 535
                It's good to do that and then use some 3M #77 adhesive to hold it in the hull then remove tape and add resin.
                2 SV 27's and Vac-U-Pickle UL-1 Power
                • bmaxx
                  • 27
                  Thanks guys
                  It will be ok to lay the cf and then add the resin on top??
                  • mdunham
                    • Apr 2010
                    • 52
                    i had to repair my sv and i used zpoxy for some repairs and i found it not very friendly to sanding.... i used Bondo-short strand, then light Bondo to finish it off and it was very user friendly!! and much easier to work with!!
                    • wizard122
                      • 535
                      Thats the way to do it take your time and don't rush it and it will turn out great
                      • 20psinow
                        • Feb 2010
                        • 148
                        Originally posted by bmaxx View Post
                        Thanks guys
                        i think it may be ok to do that but its mixed thought on how to lay it up as far as i know, i put resion down and the laded my glass then resion on top of that but thats just how i did it.
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          Bottom & top for me as well!
                          • wizard122
                            • 535
                            The 3M #77 Is a lite tack just to hold in place makes it alot less messy its the resin that does all the work
                            • tiqueman
                              • Jul 2009
                              • 5866
                              Me too.
