What is the best all around prop for the SV27????
  • Tbone2000
    • Jun 2007
    • 39
    I have been looking into buying a new prop for my SV27 electric and this is what I have come up with from browsing the forums:
    - CF48 (ultra fast but puts lots of stress on esc/motor)
    - CF45 (Stock prop??????)
    - Octura M445
    - Octura X645
    If someone could tell mewhich ones would be best for all out speed and which for speed+handling it would be much appreciated
    Also, I have noticed that some boats have a nice aerodynamic propeller tip/bolt at the end of the prop shaft. What is this and where can I find one. Thanks!!!!!!
  • Fast Guy
    • 135
    I would say the CF-45 for speed+handling. I like the M445 the best but you get a lot more prop walk and torque than the CF-45 although it is faster. The stock prop is very close to a X440-3. The X440-3 and X642 are the speed champs. The X645 and CF-48 are too much prop and heat things up real fast.
    • ice329
      • 797
      A CF45 is my choice and is not a stock prop, for the money is my number one all around choice. Next is a tie with the X642 and the M445 but watch the M & X with stock cooling, x645 may be to much. Watch all of them with stock cooling. The X642 may be be a better choice, the boat will be fast and more controlable, the M is a wild type ride. The CF48 (fast) a must have to for 5 bucks but again watch temps and stress and she will hop on the turns.
      Here are the nuts you asked about http://www.offshoreelectrics.com/products.php?cat=38
      • Tbone2000
        • Jun 2007
        • 39
        Thanks for your input!!!!! Looks like I am going to go with the CF45 and maybe also the X642. Can these props be purchased on this site or is there another site to purchase these. Thanks again!!!!!
        • Fast Guy
          • 135
          You're in luck, you can buy them here. Best prices and best service.
          • ice329
            • 797
            Sort of out of luck to..... there out of stock. Not to be in for several weeks. If you find someplace that has them, please let me know. I will agree prices and service and shipping...second to none
            • raymund629
              • 28
              I got the cf45 and the cf48 but I can't install it in my SV. Its just too loose. Do we have to change the the strut if we have to install these props? Or is there any modifications that should be done? I just wonder why its loose on my boat. got this boat brand new from a hobby shop.
              • Steven Vaccaro
                Administrator
                • 8932
                The 45 and 48 should fit just fine on your shaft. Can you take a picture of whats going on nd post it?
                Steven Vaccaro
                • Steven Vaccaro
                  Administrator
                  • 8932
                  Also a bunch of props came in on Friday and expect more today. I will be updating the site tonight.
                  Steven Vaccaro
                  • raymund629
                    • 28
                    I just can't understand why the cf45 and cf48 props I have are loose on my SV shaft. Right now i'm running an Octura 440/3, and they fit very well. If the 440/3 prop fit well, then the 45 and 48 should fit well also, isn't it? I'll take pictures and post it. Thanks for the reply Steven!
                    • raymund629
                      • 28
                      Hi Steven! I have already taken pictures of the cf45 and cf48 on my boat thru your email ad. Please take a look at it. And please let me know what you think about the props. THANKS!
                      • Steven Vaccaro
                        Administrator
                        • 8932
                        I sent this to your email address on the 18th at 11pm.
                        They fit the shaft part fine, because its 3/16". The threaded end you see in the picture is 4mm. Tighten them up and use them. There are hundreds of successful users of this prop around.
                        Thanks
                        Steven Vaccaro
                        www.OffshoreElectrics.com
                        Steven Vaccaro
                        • raymund629
                          • 28
                          Hi Steven! If I run my SV with the cf45 and cf48, will I still need to put a prop adapter over the shaft (product ID ose 1030)?
                          • ED66677
                            • 1300
                            dude,
                            the CF prop range is available in 2 different design, M4 threaded brass insert prop so called K or S series, and 3/16 bore prop so called DD prop (Drive Dog)
                            the M4 K and S series goes on any shaft that has and M4 thread and M4 nut, the nut goes between prop and strut.
                            the DD serie require a Drive Dog (in front of the prop) OSE ID oct-oc6dmm or Graupner equivalent.
                            the DD serie can go on 3/16 shaft no matter the size of thread at the shaft end, M4 or 10-32 (I guess) without any adapter.
                            the DD also fit 4mm OD shaft with M4 thread (standard european size) using an adapter, OSE 1030 or Graupner bullet style 2320
                            hope this help
                            Emmanuel
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              I think the confusion comes from the fact that the sv shaft is 3/16" but the threaded part is a smaller 4mm. But you wont need an adapter.
                              Steven Vaccaro
