Re SV 27 Motor and Propshaft
  • silvermansteve
    • Aug 2009
    • 147
    Hello. I really appreciate this forum. My questions today arise from my trying to re power an SV27 with a bad motor.
    First: I measured the stock motor and it is 36mm-50mm, and NOT 36mm-56mm. Why is this? Is a proper, size-for-size replacement a 36-50 motor, and not a 36-56?
    Second: I happen to have a 36-50, 1500kv motor sitting around. Will this work well here?
    Fourth: Is the stock esc or even a 40amp esc sufficient?
    Thanks to everyone . . . .
    Steve
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Either size will work fine in the sv. The sv 27 was my first brushless boat and I have had a lot of fun learning from it. I ended up selling the stock motor and replacing it with the Ammo 2300kv motor. But the stock motor is actually ideal for the boat. I believe it is a 6-pole motor which has a ton of torque! My ammo is a 2-pole motor(not as much torque) and in my opinion too high of a kv rating. It seems that any speed much over 40mph and the sv wants to take flight. I cant run my ammo 2300 at full throttle(even with a small 37mm prop) It is too unstable. Your 1500 kv motor should work fine. You will see a decrease in speed obviously because of the lower kv-rating. And your stock speed control is 45-amps an should work just fine. Also if you are not using lipo batteries already, consider the investment. Going from nickel cells to lipo was the single biggest upgrade I made for my sv. I gained 5mph from switching to lipo. Good luck!!
    • Jeff Wohlt
      • 2716
      I think the stock motor is around 1800KV but the 1500 will work and you can probably prop up a bit if running 4S
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • silvermansteve
        • Aug 2009
        • 147
        thank you both. i have it installed now. I will try it out with lipos too, i will probably solder in the lipo saver i have sitting around, as i'm still using the stock esc for now.
        • BHChieftain
          Fast Electric Addict
          • 1964
          A friend of mine runs his SV with a UL-1 motor and it works great,
          -Chief
          • Diesel6401
            Memento Vivere
            • 4203
            -Chief
            I run my SV with ul power and love it!!!!
            - Diesel's Youtube
            - Diesel's Fleet
              • 9479
              What do you like best about your setup?
              • Diesel6401
                Memento Vivere
                • 4203
                It's just a nice upgrade over the stock. The boat seemed really happy with the speed and behaved really well. My buddy has a ammo 2300 in his and that thing is just wicked fast, it's just too fast for me. I feel more comfortable and I think the boat feels comfortable with it is a well. I'll get the gps speeds you asked for, I'm in the process of ordering a new one.
                - Diesel's Youtube
                - Diesel's Fleet
                  • 9479
                  Right on man!
                  thanks
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1679
                    I have a 12l for sale in the swap shop. This motor is faster than the stock one and I have run it on the stock speed control with no problems. Here is a little clip of it.
                      • 9479
                      Looks goon man!
                      what kind of speeds did you get out of it, and what prop did you like with that motor?
                      thanks
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1679
                        No idea on the speeds as we don't gps our boats. I was running a x442 with added cup and temps are all under 140 for a 4 minute rin in humid Hawaii weather.
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          Well gps'd the boat today. This time I ran with 2x 2s Turnigy 4000mah 40c's and I hit 47.4mph with trim tabs & strut neutral. Boat ran very well no hopping or bouncing. Looked GREAT on the water. Still used a grim 42x55, man I love that prop.
                          - Diesel's Youtube
                          - Diesel's Fleet
                            • 9479
                            47.4mph, Sweet!
                              • 9479
                              Does anyone think the 11L form HC would be to much for this boat?
                              I've also thought about the Turnigy 3556 1800kv?
                              I had my 3rd SV motor go on me today!
                              I had a cooling issue and she got a bit to hot and slightly demaged the rotor..
                              temp was 176* at the end of the can
                              I was running 5s on a S220 prop and made some fast passes and did a massive flip and back spin that sent my SV upside down for several minutes.
                              after drying things out, I tried to back up the speed on the GPS but noticed the boat seemed slower?
                              but I did manage 47.2mph on 5s right before I brought it in.. and checked the temp of 176*
                              so I don't know if the 55.7mph was a fluke or not
