Hull reinforcement
  • Diesel6401
    Memento Vivere
    • 4391
    Originally posted by GIESDOG View Post
    I am hoping to get it in the water this week. I've got two 4500mah 7 cells and 4 cell receiver pack. Hope to get a decent run in. Anyone know a good total weight for this hull to operate at? Just worried I could be too heavy. Maybe a different prop better for low end, I am not real worried about top speed as much as I am handling and longevity.
    Thats a lot of battery weight. 7 cells are pretty heavy, switch to lipos too lighten up and you also won't need that receiver pack. If you don't want to make the lipo jump and wanna run 7 cell, drop the receiver pack and add a cc bec for $20. Saves weight and don't need to worry about your receiver pack dying on you.
    - Diesel's Youtube
    - Diesel's Fleet
    • GIESDOG
      • Jan 2010
      • 28
      I have read that running with 14 cells you can have issues with receiver, some are advising to remove the bec and run separate receiver pack to eliminate the issue. Not sure if it is true because I haven't tried it out yet, just didn't want my first run to result in a runaway boat. Lipos are definitely in the future, sadly I had just bought two matching 3 cells for my traxxas truck. Wish I could use them in the boat.
      • Diesel6401
        Memento Vivere
        • 4391
        I ran 14 cell without an issue a few times then I bought that CC BEC i mentioned in a previous post and disconnected the bec from the esc and it ran perfect. That bec is way better than a receiver pack imo. http://www.offshoreelectrics.com/pro...tle-bec&cat=75
        *With lipos of course you will need a lipo shield for your stock esc.
        - Diesel's Youtube
        - Diesel's Fleet
          • 9481
          Originally posted by BHChieftain View Post
          I bet the handling will be better-- I think the SV is too light, esp. on lipos (that would be known as a "high class problem"...). My friend's SV bounces all over the place, my son's Fastech is rock solid. Getting some weight towards the nose would be even better...
          -Chief
          could be more than just battery placement..
          if the strut and tabs are not set correct, one could have a bouncy SV
          • GIESDOG
            • Jan 2010
            • 28
            Alright, I finally got the boat in the water. Other than the cavatating prop it ran well. I think the 14 Nimh cells are a bit much in the weight category. Definitely going to get some 2 cell lipos. I shot a video which is kinda crappy, but I am having trouble with viewing it. Anyone know anything about .mov documents. I tried viewing it in Quicktime and Windows media player. Quicktime just shows a pink and gray fuzzy screen WMP can't open it at all. Sucks. I have tried wathcing some other videos posted on this site and got the pink fuzzy screen as well. anyone know a program that can open these files correctly??
            • Diesel6401
              Memento Vivere
              • 4391
              What OS are you running, Vista?
              What prop are you using?
              - Diesel's Youtube
              - Diesel's Fleet
              • GIESDOG
                • Jan 2010
                • 28
                Running windows xp, and i downloaded the most recent quicktime version thinking that would fix the problem but it didn't. The sound comes through fine but no picture.
                Using the stock prop, I have a 2 blade CF 45 prop, need to try it i guess though i'm not sure if it will help and I think it is going to run a bit hotter.
                • GIESDOG
                  • Jan 2010
                  • 28
                  oops wasnt sure i posted last message
                  • GIESDOG
                    • Jan 2010
                    • 28
                    can i post the video here or does it have to be in a link to website?
                      • 9481
                      you can post here!
                      • GIESDOG
                        • Jan 2010
                        • 28
                        what a difference a prop makes. Changed to the CF 45 and it was a totally different boat. I also moved the batteries back a bit to put the COG back to 8 in previously was at 8 3/4 in. Wish I had a video of that run. changed a few settings and i'm now able to see my video, tried to post it but having trouble.
                          • 9481
                          its awesome what changing props can do for you..
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            Grab yourself a grim 42x55 and hold on.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • wizard122
                              • 535
                              Check out my post's my SV has a Ammo 2300 on 2x 40c 5000 Diesel let me borrow that prop and my boat went 53.7 mph
                              2 SV 27's and Vac-U-Pickle UL-1 Power
                              • bmaxx
                                • 27
                                I am in the middle of trying to reinforce my hull, and was thinking of a way to replace my soft water logged motor rails. I kind a like the lexan idea, How do you fasten it to the hull? I am very new to this sport, and I am loving it.
                                Thanks
