Smoked a new SV 27 Motor!
  • bigwaveohs
    • 606
    First run on our SV 27: (2) 4500mAh 30C LiPos w/X440/3. Motor fried in 4 minutes. What did we do wrong?
    I let the dogs out...
  • egneg
    • 4759
    Sorry to hear it ... if I could answer that I would not have fried my Etti in 3 minutes!
    IMPBA 20481S D-12
    • Diesel6401
      Memento Vivere
      • 4391
      I know when I received my SV from Tower the drive shaft wasn't hardly greased at all and their was a tiny piece of the packing styrofoam that protect the rudder inside the box clogging the rudder pickup. I'm new to the hobby and don't know that much, but it could be things like that may have made the motor work that much harder or not properly cooled. Or just bad motor from stock. Sorry bout your luck, it's a super fun boat.
      - Diesel's Youtube
      - Diesel's Fleet
      • bigwaveohs
        • 606
        When we got the SV 27, the shaft was a total mess...goo instead of grease so I cleaned everything, ran in the bushing at the stinger with an electric drill and greased with GrimRacer cable grease. It was perfect before we ran it...I suspect that there was something wrong with the bearings and that they were binding. This pulled excessive current which in turn fried the windings.
        Comments?
        • Diesel6401
          Memento Vivere
          • 4391
          Comments?
          Ouch, sorry bout ur luck
          - Diesel's Youtube
          - Diesel's Fleet
          • slyman
            • Jan 2009
            • 126
            Was water flowing through the cooling lines?
            • bigwaveohs
              • 606
              Water was shooting out of the water outlet to about 12" to the side of the hull and the ESC was hot but not fried like the motor...very strange. I have a VS-1 tunnel with a UL-1 motor and the same waterjacket as the SV 27 and the UL-1 motor runs cold at 50mph!
              • m4a1usr
                Fast Electric Addict
                • 2036
                You might have had a bad connection on one of the motor leads. The wires can be hard to get to a good solder joint on. I'm assuming the end bells did not pop loose?
                John
                Change is the one Constant
                • slyman
                  • Jan 2009
                  • 126
                  Contact your dealer if this was a new boat for a possible warranty claim. I have found that Aquacraft stands behind their products.
                  • bigwaveohs
                    • 606
                    It was our LHS...wonder if I should contact Aquacraft directly? However, all I could find was Great Planes the distributor...???
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      Hobbico Inc; aquacraft, great planes, duratrax and pretty much a bunch of other well known brands are all under the Hobbico Inc brand. To answer your question Great Planes is a distributor their all the same. http://www.aquacraftmodels.com/techsupport/index.html hopefully this helps
                      - Diesel's Youtube
                      - Diesel's Fleet
                        • 9481
                        Comments?
                        If your talking about the motor, they turn over very hard by hand..
                        normal for this
                          • 9481
                          John
                          I had this happen on one of my SVs.. I thought I burnt the motor and found a loose connector on the motor..
                          • bigwaveohs
                            • 606
                            The motor was so hot that white smoke was coming from under the hatch when we brought it in...you could fry eggs on it!
                            The insulation burned off the windings...the bearings are toast too!
                              • 9481
                              ok now I understand its not the connectors..
                              that sucks and I have no Idea why unless the stuffing tube was not installed right..
                              my budy took a SV backs because the stuffing tube was installed wrong and caused alot of drag on the shaft and poped the esc
