ammo motors
  • forescott
    Hopelessly Addicted to RC
    • 3009
    I agree, the ammo 2300 will heat up really fast with that prop. My 642 runs pretty hot, I am gonna try out the octura x640
    • wizard122
      • 535
      Just got back from the pond with my new Ammo 2300 tried alot of props today.
      started with a CF40 ran ok 41.5 things got a little warm
      than ran stock prop only ran 38.5 got real hot about 130 deg alot of slip
      X442 ran 42.3 not as hot 122 deg shrink wrap on Deans plug melted ????
      My switch to 5,5mm Bullet connector
      Grim Racer prop 40 X 52/3 ran 46.3 and much cooler about 120 deg
      Still my fav Prop
      2 SV 27's and Vac-U-Pickle UL-1 Power
      • Diesel6401
        Memento Vivere
        • 4391
        Still my fav Prop
        46.3 awesome man, wish I was their to see that. Great work!!!!
        - Diesel's Youtube
        - Diesel's Fleet
        • forescott
          • 3009
          Do you have any stability issues at that speed? Mine chine walks like mad over 40mph.
          • forescott
            • 3009
            with the same prop.
            • Ctonez
              • Jul 2007
              • 410
              I really like the 437/3 blade with the Ammo 2300kv.
              • forescott
                • 3009
                Anyone having any speed control issues with the ammo? Ive been through 2 seaking 60a speedos that mysteriously quit working with my 437/3. I just read the specks on the ammo which shows a constant amp rating of 60. Are my speed controls to low of an amperage? I thought guys were running the Ammo 2300 on the stock 45A aquacraft speed controls? Also I cant run the boat full throttle without it porpoising like mad. Will running the boat 1/2 to 3/4 throttle heat up the speed control or increase amp draw?
                  • 9481
                  Still my fav Prop
                  I wonder why you only see that speed with the Ammo, when I've gone 39.4mph with the stock motor?
                  I'm doing some testing when the weather clears running 5s on a stock setup
                  • wizard122
                    • 535
                    I'v gottin 39 plus with the stock motor and 50 plus with the Ammo motor all running stock ESC no problems and the temps are good.
                    • Ctonez
                      • Jul 2007
                      • 410
                      I ran my Ammo2300'ed SV with a Barracuda 125 and 437/3. Partial throttle will heat things up and be harder on the controller, but considering other peoples experience, I'd think 60amps should be enough. Is it on plane or are you plowing water alot at partial throttle? Plowing is bad and really draws amps. The porpoising is likely caused by the CG being too far back (I have my Lipos even with the front of the motor), strut angle being incorrect (mine is a hair lower than neutral, but neutral should work too), or Tabs too deep (mine are 1/16 above the bottom of the transom and neutral).
                      Maybe the ESC's are thermalling? At least they aren't burning up.
                      Long runtime will also heat things, how long are you running?
                      • Ctonez
                        • Jul 2007
                        • 410
                        I highly recommend resoldering all the connectors on the motor leads. The factory solder will let go with use and heat. Seen it happen multiple times.
                        • Ctonez
                          • Jul 2007
                          • 410
                          Originally posted by jlr3rd1 View Post
                          awesome, i am running an x 645 prop:) the motor just doesnt sound like it has much power???? and it s 24 degrees outside
                          Don't put it in the water with that prop.
                          42mm or less...
