ammo motors
  • pugman2
    • 236
    ammo motors
    as a direct repacement type motor is the ammo worth useing as a stock upgrade as far as quality and power my factory motor still works fine if its not worth it ill leave it alone and work on other issues
  • pugman2
    • 236
    anyone? must be a dumb question
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      The Ammo 36-50-2300 is an upgraded motor that is just a plug & go in the stock system. You will notice a vast improvement in speed with it.
      • 785boats
        Wet Track Racing
        • 3169
        You will need to prop down a bit though. The Ammo needs to rev or it draws a lot of current.
        X440 X637 or the Grim Racer 40mm X 52/3 blade all work well as a starting point.
        • Diesel6401
          Memento Vivere
          • 4203
          Would a CF40 be ok with this motor?!?
          - Diesel's Youtube
          - Diesel's Fleet
          • Diegoboy
            Administrator
            • Mar 2007
            • 7247
            Stock ESC, Ammo motor & Octura X642 run VERY well.
            ...ask me how I know.
            • pugman2
              • 236
              ive been running x440 been a good prop but dont know what it would do with that motor
              • Diegoboy
                Administrator
                • Mar 2007
                • 7247
                I had an SV27 that ran the ammo on an X642. It ran great except for the inherent Sv27 issue of being "belly up" (which had nothing to do with the motor or prop because she spent the same amount of time on her back with the stock setup) Dirtysouth31 ran the SV with an ammo on an X445 with no issues.
                • 785boats
                  Wet Track Racing
                  • 3169
                  Diesel
                  Yep, the CF40 should work. But as I said in the previous post they are starting points. Work your way up. As you can see others are running bigger props.
                  An X637/3 blade is another good one.
                  I haven't got one, but I reckon an M640 would be pretty quick.
                  Anyone out there tried that one? Or maybe the M642?
                  Cheers.
                  Paul.
                  • bigwaveohs
                    • 535
                    never mind.....
                    I let the dogs out...
                    • bigwaveohs
                      • 535
                      never mind.....
                      • jlr3rd1
                        • 240
                        question ? i installed the Ammo 36-50-2300 motor and when test running the motor it doesnt sound like its has the power of the stock motor??? the flex shaft and prop turns freely????
                        2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
                        • forescott
                          Hopelessly Addicted to RC
                          • 2686
                          Its supposed to turn freely, unlike the stock motor. I just put one in my supervee and it rips! Got 46mph on octura 642 before it took flight!
                          • jlr3rd1
                            • 240
                            awesome, i am running an x 645 prop:) the motor just doesnt sound like it has much power???? and it s 24 degrees outside
                            • egneg
                              • 4664
                              That prop is to big!
                              Try a Prather 215
                              IMPBA 20481S D-12
