Motor getting hot stationaire drive
  • hilco
    • 3
    Hello,
    Question : at a stationaire run - not in the water - no watercooling on - free run.
    Is it normal the the motor is getting hot (after 30 sec. you can not touch it any
    more). Stock motor.
    I tried another brushless motor (non stock 2300KV), this one does not get hot at all (just a little warm).
  • Unsullied_Spy
    • 91
    Brushless motors are horribly inefficient without a load placed on them and can burn up if run out of the water. It is normal for them to get hot, but really not advisable.
    • RCprince
      • Jul 2007
      • 1637
      30 seconds! ditto above comment. There is no reason to run a BL motor out of water for that long. doing similar my cousin or I could have lost an eye, I revved a motor with a prop on it, and the prop was not balanced well enough...any way, it broke the shaft and flew across the room...that could have been and eye! an 8th of a throttle for a second to see if its working and the rest is for the water. These are not toys, just miniaturized machines.
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • hilco
        • 3
        Thanks guys, i did not know how serious the action was. Will do the testing in the water. I have ordered additional to the stock motor an Turigny 2300KV motor (according to me the same as the ammo), and will maken as soon as i have received it test runs - in the water - Anyone advise running this motor ? I have the stock controller.
        • hilco
          • 3
