My new SV
  • z400
    • 1333
    #61
    leads???
    more than enough length. I run all my boats, cars, and planes this way..
    more connectors could mean more resistance
    Well my freakin bad buddy.
    I'll think before i share my experience next time when your around.
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
      • 9481
      #62
      right on, I run my SV this way and it works great!
      and in my MM that is wider
      • wizard122
        • 535
        #63
        Thanks agian its so much cleaner with out all those wires in there. I have a Turnigy 8150 charger I can charge 4 packs in about an hour and 15 mins I love it.
        2 SV 27's and Vac-U-Pickle UL-1 Power
        • GIESDOG
          • Jan 2010
          • 28
          #64
          Wizard nice setup, question on the cooling jackets, the first one you had installed was it for a 540xl and why the switch?
          • Diesel6401
            Memento Vivere
            • 4391
            #65
            As long as you use both of your balance tabs hooked up to your charger..
            my charger only goes upto 5A so I only charge one at a time.
            Just confrim my thinking charging the way you have pictured just charge 2 2s batts at 4s @ 5000mah correct since it is in series (voltage double, mah constant). I am just reassuring myself, I don't think the wife would be happy if I burned the place down lol. Also where might I grab a balance board with 2 2s slots?
            - Diesel's Youtube
            - Diesel's Fleet
              • 9481
              #66
              You are correct my friend!
              after posting that picture I thought about that and now realize I can charge two and even three of my 2s packs at the same time, as long as I have the balance tabs hooked up..
              that would save me alot of time durring charging
              • Diesel6401
                Memento Vivere
                • 4391
                #67
                after posting that picture I thought about that and now realize I can charge two and even three of my 2s packs at the same time, as long as I have the balance tabs hooked up..that would save me alot of time durring charging
                Do you have a balance board that can support 2 2s batts, If so where did you get it from?
                Wizard if your still following I know you have one I just forget where you got it from.
                - Diesel's Youtube
                - Diesel's Fleet
                  • 9481
                  #68
                  I don't have one yet, but they can be bought from Hobbycity..
                  the connector will allow charging three 2s packs at the same time, or you can get one that will balance two 2s packs at the same time
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    #69
                    Cool I need I have somethings I need to grab from HC anyway so ill add it to the list. If you have a link it would be great.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • wizard122
                      • 535
                      #70
                      Changed to Ammo 2300
                      The stock Sv motor has that jacket but the Ammo motor is shorter so I went with the OSE jacket
                      • wizard122
                        • 535
                        #71
                        Charging two packs at once
                        So here is how I charge two packs at one time please be carefull you can short things out fast if you hook it up wrong follow the photo and you can't go wrong.
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          #72
                          Sweet!!!!!!!!!!!!
                          - Diesel's Youtube
                          - Diesel's Fleet
                            • 9481
                            #73
                            Bingo!
                            I need to find me a balance tab so I can charge three 2s packs in series..
                            I would be nice to charge 3 batteries in the same time it takes to charge one with my charger
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              #74
                              Bingo!
                              Wizard called me yesterday and pointed me in the right direction. Here's what I just order and this is what wizard is showing in the pic above. I ordered 2 of them since I have 2 chargers. http://www.helidirect.com/multibalan...pb6-p-7595.hdx
                              - Diesel's Youtube
                              - Diesel's Fleet
                                • 9481
                                #75
                                Perfect! that's just what I need..
                                One thing though, I did try charging 3 2s packs just 30min ago without the balance tabs and notice the max amps my charger charged at was 2.3amps..
                                that sucks, so it would till take a long time to charge 2 or 3 batteries at the same time with the charger I have
