Fine tuning a SV27
  • sunsation288
    • 128
    Fine tuning a SV27
    Hi all , since me and my son have the same boat , i don`t know why is boat scream compare to mine , we have the same setup , Lipo shield from Dimension Engenering , Lipo 5000 20c , the only chance i have is when he put is 3 blade (the one coming with the Kit ) , and i put a 2 blade (grp-2317.45) , we can have fun , but is boat have more punch ,
    what i done so far is
    adjust the trim tab and Strut equal to is boat
    Question
    1- on the pistol control what is the purpose of D/R knob ?
    2- my option is a data logger ?
    Sorry for my bad english , if i am not clear , feel free to ask
    Regards
    Christian
  • sunsation288
    • 128
    Ok what i have found for the D/R knob is adjustable steering rate ? that made sense ?
    • tiqueman
      • Jul 2009
      • 5866
      Yes, D/R control the amount of steering that you have.
      Have you tried taking your sons prop and puting it on your boat, put your prop on his. Is yours now faster than his? It could be the difference in props? A 3 blade prop may work well at one strut angle and height, where as a 2 blade may not work at that exact setting. Usually you have to do a little bit of adjusting to everything, at least I have found, when going from a 2 blade to a 3 blade...??? Just my thoughts though. Try changing the props between the 2 boats first. Let us know what you find. How are the temperatures compared between your boat and his??? According Kintecracing.com, your 45mm 2 blade should be faster but run your boat with hotter temperatures.
      Also, be sure nothing is binding or sticking in your drive shaft. Be sure to leave some space between the front of the drive dog and strut. A flex shaft will wind up and tighten under a load. If you have the drive dog (piece the prop locks into) touching the strut, it surley is binding and will slow you down.
      Hope this helps,
      Scott
      • sunsation288
        • 128
        He are faster by little
        Hope this helps,
        Scott
        Ho i think you made point here ..i will check later today, mine are definitively more closer to the strut than is , i will let you know .....you can not imagine how i appriciated your help
        a Daddy little frustated
        • sunsation288
          • 128
          Hope this helps,
          Scott
          Have you the clearance in MM ? , i am at work right now , and tonight we will try it for sure .....
          Many Many thanks , hope this the problem ....because he cheek me alot
          • tiqueman
            • Jul 2009
            • 5866
            About 3mm is what I normally do.
            Hope the problem is that simple.
            Scott
            • sunsation288
              • 128
              Scott
              Many thanks , the problem are still there , my son play with me , i noticed the alignement between the motor and Flex Cable ....i will keep you posted
              Regards
              Christian
              • tiqueman
                • Jul 2009
                • 5866
                Lets stay on the simpe page. Does your son have "his" set of batteries and you have "your" set? I know you are running the same 5000 20C. But have you tried all batteries in your boat?
                Yes, be sure the motor is inline with the flex shaft. Be sure the flex is well greased. Loosen the motor shaft collet where the flex connects and be sure the flex spins freely inside the stuffing tube.
                If all of that seems ok... maybe try switching the motor and esc between the two boats? But, do one at a time so if it is the motor or esc, you know which one it was.
                We will get this figured out...
                Scott
                • tiqueman
                  • Jul 2009
                  • 5866
                  Can you post us some pictures of both boats? Inside and out?
                  • sunsation288
                    • 128
                    Scott
                    Many thanks Scott for helping , yes we try to exchange the batteries ...and same result , he pass just enought to be able to laugh at me
                    • sunsation288
                      • 128
                      Ok what i found so far , is the front of the tube un-glue ? , i just re-epoxy it with taking care of align it
                      but after tonigh run ....i am still behind him
                      • sunsation288
                        • 128
                        Sorry guy to be long between post , our lake are too big , and a small wind can generate too much wave ...for helping you to wait ....a video of me and my son in the legendary Drambuie on Ice winner of World Champioship APBA 2001 ...a 42 MTi catamaran
                        • tiqueman
                          • Jul 2009
                          • 5866
                          Yes, if it needs to be epoxied or glued again, be sure it is aligned as perfect as you can get it.
                          Take some more pictures also of both boats.
                          Have you tried switching ESC's or motors? If you do, do one at a time so you know which made the difference, if it is one or the other.
                          Drambuie pictures look great!
                          • sunsation288
                            • 128
                            Don`t forget the video ...me and my son on a 123 mph ride
                            • sunsation288
                              • 128
                              Ok since weather suck today ...i install the Eagle 3 ...and made some dry test ...(i think is not good ...but i made realy short full trigger ) i made 17.3 amp draw , and my son with the same batteries pack 24.28 amp ....
