Repair or replace?
  • Tony Vega
    • Aug 2009
    • 39
    Repair or replace?
    Took the boat out today and was having a blast. Caught a wave and bam...barrel roll and now I have some hull fractures. Both along the port side of the boat with one being very close to the front and the other around the water outlet. Boat still floats but I would want to repair it before it gets worse. Is the boat totaled or could the hull be replaced? I know with some effort it could be repaired.
  • Tony Vega
    • Aug 2009
    • 39
    Anyone reputable want to earn some $$$ to fix my hull? I am too lazy to fix it.
    • domwilson
      • 4411
      Got Pics?
      Government Moto:
      • scooterP
        • Jul 2009
        • 250
        Are the fractures just in the gell coat or all the way through the hull? I have some small hairline stuff, but they don't go through the glass work. I'm going to strip mine down this winter and reinforce the hull and then do the "cosmetic" stuff.
        Also, you can buy just the hull.
        • Tony Vega
          • Aug 2009
          • 39
          Where is the hull available? The fractures look like they are all the way thru. Pics coming soon.
          • z400
            • 1333
            Sounds just like the well known cracks the SV gets along the seam where the 2 halves of the hull come together.
            Would like to see pictures.
            Its a pretty easy fix, just takes time.
            Z
            KBB34" Mono - Fast
            ToySport Triton- Not as fast
            • Tony Vega
              • Aug 2009
              • 39
              Pics as requested...
              Upon further inspection in proper light I see hairline fractures all over the bottom as well. Those however appear to be just the paint. Is this a common occurrence in these boats? Has anyone had any success in warranty replacements from the factory? One barrel roll and this happens??? Certainly it should hold up better than this. Other than the second turn fin, this boat is all stock and was on it's maiden voyage.
              • z400
                • 1333
                Very common and yours are pretty minor.
                if you look closely, you can see i have 2 cracks running almost the entire length of the boat on either side of the boat where the 2 halves of the hull join-
                Hard to see but they are there.
                Its a easy but slow fix.
                Everynow and then i'll read about some one going through the procedure to fix the cracks.
                Is it worth it? Not at the stage right now that your cracks are at.
                Z
                KBB34" Mono - Fast
                • domwilson
                  • 4411
                  As Sean stated, those look very minor. They appear to be cracks in the paint. If water doesn't enter the hull thru them, I would just ignore them. But for a little extra peace of mind, you could always apply expoxy on the inside of the hull where the cracks are located. If the paint flakes off. Apply epoxy over that, sand and paint with a matching color.
                  Government Moto:
                  • Tony Vega
                    • Aug 2009
                    • 39
                    Well I performed a pool test and its taking in water around the cracks. I have decided to strip it down and reinforce it so I can prevent this from happening in the future. I have everything out of the hull except the tube that the flex shaft rides in. Does anyone know how this comes out? Or does it at all?
