Rio ep brushless prop help!!!!
  • bracka69
    • Jun 2011
    • 298
    Hello,
    I have a RIO EP that I converted to a brushless setup using a pro boat 1800kv motor with a seaking 120a esc. I plan on running it on 4,5 and 6s. What prop would you guys recommend for me to use with this setup?
    Thanks
    Joshua
    • 4297
    Hey,
    I run 3s on a 2600kv motor and t120 esc with added caps & x440/3 prop and the stock hull can just handle it at 32 mph,
    I tried 4s once and was way to much for the boat.
    Hears a link to Jesse J Rio and modding and videos. http://forums.offshoreelectrics.com/...IO-EP-Overhaul
    • Make-a-Wake
      FE Rules!
      • 5554
      "Rio ep brushless prop help!!!! "
      Any more than 4s is just ridiculous................a plastic hull to cram 25 volts into? Your large number of exclaimation points would indicate a real urgency to me............. you got a huge SAW race coming up in the next day or 2? I cant recommend any prop since the whole setup is highly unusual and is way out of any normal realm of standard FE boating............especially for a plastic boat.
        • 5660
        I use a Proboat 1500 kv motor with 4s lipo and the stock 42mm prop, it runs pretty well. Remember the hull was designed for a much slower speed threshold. To give you an idea:http://www.youtube.com/watch?v=iCSzh...hannel&list=UL
        • bracka69
          • Jun 2011
          • 298
          Thanks Lenny I will check it out.
          • bracka69
            • Jun 2011
            • 298
            Hey Make-a-Wake.
            I guess i got carried away with the exclamation marks. Me and some friends did this setup to see what we could get out of this little hull. Had the stuff laying around and wasnt using it so we decided to try it. On 5s with the stock 42mm plastic prop it has a lot of torque roll, so much that it will roll completely over and keep on going lol.
            • bracka69
              • Jun 2011
              • 298
              Hey tlandauer. Thanks for the info and video link.
              • Killah2469
                • Oct 2012
                • 112
                Does anyone know the pitch on the stock prop?
                Check out my youtube channel
                  • 5660
                  Can't be more than 1.4, that is my guess. of course I have been wrong before.
