I want to add a set of rudders with water pickups to my Rio EP: any recommendations for the easiest rudder to fit to the stock EP mount, or the best water pickup rudder that can be fit to a Rio EP transom?
Rio EP Replacement Rudders With Water Pickup - Suggestions?
Hi, This would work good with one or two on the Rio.
http://www.offshoreelectrics.com/pro...prod=ose-80052
Thank you for the suggestion. I have decided that swapping the dual rudders for dual rudders with water pickups is over my head, since the closest direct swap that I have seen is @ http://accu-techrchardware.com/siteb...s4-555x308.jpg ...but even that blade is not a match for the mounting points on the Rio rudders. I want to maintain the slow speed manveurability of two rudders. So, I installed an Octura Streamlined Water Pickup: see photos of that install @ http://s985.photobucket.com/albums/a...In%20Rio%20EP/ I can only hope my boat looks as good as your Rio when I am done!
