rio set up questions
  • Trevor January
    • 30
    well i have went to a brushless set up on the rio ep and wow it's awesome but it seems to have some issues
    to start it has mad torque roll action going on which i can't seem to figure out how to stop any ideas?
    and i see that alot of people are using a whole new set of hardware over the stock stuff is this really the way to go to make this hull awesome or is it just an extreme mod ?
  • Diesel6401
    Memento Vivere
    • 4391
    Post your setup, motor/esc/prop/batteries and we may be able to help you.
    - Diesel's Youtube
    - Diesel's Fleet
    • hyrulejedi86
      • Aug 2009
      • 500
      You won't be able to completly eliminate it. I have found that with mine, I max out at around 28-30mph before it torques too hard. Even after adjustments of the trim tabs.
      If anyone does have a good suggestion to fixing it I might try it also.
      • Trevor January
        • 30
        okay i a running for set up
        turnigy 3900kv which i like a 380 size can
        turnigy 60amp modded airplane esc with a cooling block
        and 37 3 blade the stock supervee 27r ones
        and two 2s 1800mah in parallel
        stock hardware and everything but i gutted the whole in side laid carbon cloth down and put in a new mount
        hope this well help
        • Diesel6401
          Memento Vivere
          • 4391
          hope this well help
          Are you using a 1/8 or 3/16 flex cable? You may need to prop down a little, maybe to something like a y534 or a x435. It may not fully elimanate your problem, but may help.
          - Diesel's Youtube
          - Diesel's Fleet
          • hyrulejedi86
            • Aug 2009
            • 500
            Now, that I think about it I had tried a smaller three blade myself and it definetly made a difference but I had slower speeds from it.
            • Diesel6401
              Memento Vivere
              • 4391
              Yup propping down will normally help with torque roll, but sometimes the trade off is top end speed and or getting on plane. You may have propped down a little to much depending on how much speed you lost.
              - Diesel's Youtube
              - Diesel's Fleet
              • Trevor January
                • 30
                cool something to consider it's better to run slower then to have problems running faster and the flex is the stock which might be 3/16 or some where around 3 mm
                thanks guys
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Ok just to recap some thing you are running possible stock drive which I think is 1/8 shaft. You are running the 37mm aq sv27 nitro prop which are 3/16 shaft. Are your using a shim? Or did you actually convert to a 3/16 shaft? That is important to know because you need to prop down and you can't get as low of a diameter prop you may need if you are running 3/16. In this case 1/8 may be better because you have can get small dia props. Hopefully that makes sense.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Trevor January
                    • 30
                    shims for the sv prop
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      Ok cool, the props I listed above may be worth a try.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Trevor January
                        • 30
                        yeah i think i will look in to i might have already had them on order for something else too
                        • Trevor January
                          • 30
                          i guess i didn't i just looked and it was 531 dang it
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            I think that's going to be way to small.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Trevor January
                              • 30
                              well some stock came in at ose so i got some props on order
                              maybe they will get here soon so i can see what the changes of the prop will do for the boat i hope it's a prop issue cause i don't really want to to put a lot more into in to it i think i would rather use the parts and time another boat that would be a much better return in the end i do have some i should build but this would make a great rescue boat
