New motor and ESC and timing
  • hyrulejedi86
    • Aug 2009
    • 500
    NEW VIDEO ON POST 16
    I just got this new motor for my Rio EP:
    And I was wondering what timing I should have the ESC set on?
    I am using the Ver. 2 Seaking 120A ESC. The timing settings are:
    0 3.75 7.5 11.25 15 18.75 22.5 and 26.25 all in degrees
    Also, when I release the throttle I hear a single "Ping" noise and I think it's coming from the motor, what is it?
    Thanks for the help
  • hyrulejedi86
    • Aug 2009
    • 500
    I have no idea where to start so I hope someone here knows.
    • JimClark
      • 5913
      how bout the middle is usually a good place to start
      Billy Graham
      • hyrulejedi86
        • Aug 2009
        • 500
        It's set in the middle by default, I just wanted to know if anyone knew the best place for it so that I don't overheat the motor or lose power.
        • Diesel6401
          Memento Vivere
          • 4391
          I'd imagine it's a 2 pole motor so timing should be low. 0 or 3.75, maybe even 7.5 at the top end.
          - Diesel's Youtube
          - Diesel's Fleet
          • hyrulejedi86
            • Aug 2009
            • 500
            Actually, I thought it was a 4 pole motor. The description "B36-56-04-2600" from their website, means, according to what others have said, 36mm diamter--56mm long--4 poles--and--2600kv.
            I could be mistaken I just wanted to throw that out there in case that helps.
            • Diesel6401
              Memento Vivere
              • 4391
              2 or 4 poles timing should be about the same.
              This may help:
              Suggested Timing: 1° (2-4 poles motor) : 7° (6-8 poles motor) : 15° (10-14 poles motor) : 30° (10-14 poles motor)
              - Diesel's Youtube
              - Diesel's Fleet
              • hyrulejedi86
                • Aug 2009
                • 500
                That does help! i'll have to change my timing over then.
                Just to clarify what does lowering the timing do for the system?
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Not fully sure, I think it changes the voltage frequency to the motor. If you would put a oscilloscope to the leads of the esc that go to the motor you would prob be able to see the difference in timing. I think brushless motors are actually DC, but kind of work like AC synchronous motors. I'm not 100% sure though, maybe a smarter member can shed light on this. Anybody here got the answer to this question?
                  - Diesel's Youtube
                  - Diesel's Fleet
                    I'd imagine it's a 2 pole motor so timing should be low. 0 or 3.75...
                    I'm not certain where this bad info keeps coming from, but it is a very poor idea to run any BL motor on zero degrees timing. It will run hot and with reduced efficiency.
                    Five to ten degrees is a good range for a 2-pole motor in the average sport boat, but the 'best' timing depends on the motor winding and the load. The more turns and the higher the load, the more timing advance is required. FWIW I ran 20+ degrees in my old Feigao-powered SAW record holder, less was slower. I had 90+ mph passes on 12 NiMH cells with that rigger.....
                    Schulze, who knows a bit about BL motors and controllers, recommends their "soft" timing as optimum for two-pole Hacker and Lehner motors, and "very soft" for low amperage applications. In Schulze-speak, very soft is ~5-10, soft is ~10-15, hard is ~15-20 and very hard is ~20+ degrees.
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      And that's y I asked the older wiser crowd to jump in. Maybe 0 isn't the best, but I wouldn't consider all the information I stated as"bad", I'm just relaying info that I read.
                      The info is coming from mulitple esc suggestions, I didn't make it up. I read that in the etti esc section on motor timing. I read esc info on hacker esc which states the following. Maybe car esc's are different not sure.
                      * 2-5 degrees, recommend for 2-pole brushless motors (which I thought it was a 2 pole first)
                      * 10 degrees, harder for 2 pole, best for 4 pole (so if it is a 4 pole and not a 2 like a thought, this would be better)
                      * 18 degrees, 6 pole motors
                      Here's the link for that http://rcnuts.com/Files/HackerCarESCmanual.pdf (page 3)
                      http://www.offshoreelectrics.com/pro...-race-150-opto
                      - Diesel's Youtube
                      - Diesel's Fleet
                        See edits on post above. I'll believe Schulze and my own experiences before I believe ETTI....appologies to the ETTI lovers here, sorry.
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          The hacker esc, states kinda of similar to the ETTI information. You have a lot of experience so what works for your in your testing maybe different than what esc makers suggest. I also edited my post to add additional information.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            This is from Hifei:
                            Option 1: Low advance timing
                            0°~15°
                            Recommended for more lower pole count motors. Gives more power and
                            slightly less efficient.
                            Option 2: middle advance timing
                            5 °~ 20 °
                            Recommended for most motors .Gives a good balance of power and efficiency.
                            Option 3: High advance timing
                            15° ~ 30 °
                            Recommended for most of higher pole count motors
                            Option4:Auto(default)
                            Recommended for most of all brushless motors.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              The "4" in the description represents the number of turns.
                              - Diesel's Youtube
                              - Diesel's Fleet
