Hello, I'm new to the forum and to R/C boats (i have planes, off-road trucks, and helis--all electric). I just installed the following brushless setup in my Rio EP:
Turnigy 36-56 2700kv motor, Turnigy 120A ESC, stock prop, and am powering everything with a Turnigy 5000mah 3s lipo.
On my first run at the pond I first noticed that the cog is off since the boat runs really wet and wants to hook to the left when I stab the throttle. Would moving the cog back help with the hooking? I drilled out the stock coupler to fit the larger diameter motor shaft and made sure all of the set screws were tight, however the flex cable came off but luckily the boat was heading toward the shore and floated close enough to where I could grab it without getting wet
Any help with my setup would be greatly appreciated, especially since this combo seems to have A LOT of power... maybe too much???
I adjusted the starboard trim tab and it helped a little with the torque roll. Also, under acceleration the whole boat kind of sinks down and plows through the water. I have my COG at about 30% by adding weight to the stern. I'm thinkin now that the motor is too far forward and I will need to modify the motor mount to get the motor towards the stern more. I'm not sure how I'm going to do this yet since the motor is 44mm on one end and smaller on the end where the shaft comes out (this is the end I have in the mount). If anyone has any suggestions, please let me know.
