ESC Turn Limit???
    • 9481
    that video does not look like a VXL powered Rio ep on 3s..
    • illz302
      • Sep 2009
      • 191
      it isnt but if the kv is the same than whats the difference?
      • Diesel6401
        Memento Vivere
        • 4391
        What motor are you running with the Traxxas esc?
        I was running a Titan 12t on a 7cell nimh. Hit 19mph with stock prop. I put the stock 550 back in though because I converted it to a rescue boat and needed lower rpm higher torque the stock motor had for pushing a stalled/flipped boat.
        - Diesel's Youtube
        - Diesel's Fleet
          • 9481
          You said it was a VXL motor, now its not..
          a VXL motor on 3s is a monster!
          almost 40,000rpm and on the stock 42mm prop tha Rio ep would fly!
          • illz302
            • Sep 2009
            • 191
            No i did not say the guy in the video was using a vxl system i said i am using the vxl system in mine and i was showing the video becuase it had a brushless system in it that had basicly the same kv rating and cell count
              • 9481
              read post #13 and on..
              I don't think the video you posted has a 3600kv motor on 3s, that would be right at 40k rpm and on the stock 42mm prop it would move out real fast
              he is posibly using a 2s pack
              • illz302
                • Sep 2009
                • 191
                im not saying that you said you were confused i was just clarifying for you 55. I dunno either that or its like a 15-20c 3s just a guess on my part. anyways ill be ordering 2s and 3s so i can try both.
                  • 9481
                  Clarifying, I'm not sure what that means?
                  I was asking about the video not your setup, because the video looks slow for a 3600kv motor on 3s with a 42mm prop.
                  the video you posted that I was talking about looks more like he may have used a 2s pack or even a 6cell nimh pack with that motor and prop
                  • illz302
                    • Sep 2009
                    • 191
                    hmmm interesting i will have to try the 2s first then and if im feeliing lucky and heat is low then ill try the 3s
                    • illz302
                      • Sep 2009
                      • 191
                      Well I ran it with the current setup with the apache esc and the apache motor and the motor died within two runs on the 2s lipo. So then I swapped in a venom 15t motor I had laying around that was used once before for a run to test in the apache and within one run the apache esc died. Thats just my luck
                        • 9481
                        the venom 15t sucks some amps, and they don't put down much power..
                        go brushless bro!
                        • illz302
                          • Sep 2009
                          • 191
                          I am now considering I used all my leftover electronics up in this boat
                          Just have to wait for more money now
                            • 9481
                            bummer!
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              My buddy blew his apache motor after only about 5 runs... SUX!!!
                              - Diesel's Youtube
                              - Diesel's Fleet
