I'm brushless
  • soulreaper
    • 58
    I'm brushless
    I finished the Rio tonight. I've had a few setbacks, but its all good now. I will be heading out to the lake tomorrow morning as long as the weather holds. I hope this works.
    Reaper.
  • Steven Vaccaro
    Administrator
    • 8932
    Great, post some pictures if possible.
    Steven Vaccaro
    • soulreaper
      • 58
      Its raining hard right now. Supposed to rain all day, (FIGURES). If the rain lets up just a little I will still attempt a test run. My plan is to place a plastic bag over the radio, however rain drops hitting the surface of the lake make it hard to see things clearly. This probably wont happen today. Sorry guys.
      Reaper.
      • soulreaper
        • 58
        On my way to the lake even though it is still raining. If I dont test today I wont be able to test until Wednesday. I'll be back in an hour.
        Reaper
        • SweetZ28
          • 1535
          Reaper
          Cool i had to do a test run in the rain one time and it was actually fun!
          will be waiting on the results
          WWW.PPRSLOTS.COM
          • chummer
            • 650
            What motor and ESC did you put in it? Waiting to see how you made out...
            "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
            • soulreaper
              • 58
              Hi guys had a couple of problems. First the Pistix that Im using in order to use my airplane esc would not let me go full throttle. When you applied full throttle it would reach max rpm for one second and then go to 75 percent throttle. I noticed that when I originally set up the Pistix it did that with the servo (thats how you orginally set up the Pistix). The servo would go to full travel and then back off by itself. Second the prop walk was uncontrollable. No matter how slow I tried to apply the throttle the boat just tried to roll itself over. I tested with the stock prop that came with the boat. The boat was still alot faster than stock.
              Solutions. I finally figured out how to make my airplane esc work without using the Pistix. Now I get full throttle. (Problem solved) second I found a smaller prop that I had ordered my Apache 24 that did not fit the shaft. Well the prop fits the Rio. I dont remember what size the prop is. It is alot smaller. So after typing this I'm headed back to the lake for another trial.
              The motor never got hot on the first test runs. The motor is a EZrun 2350kv monster truck motor. I run the same motor in my traxxas E-maxx, which weights 8+pounds. The Ezrun has more torque and power than the TWO stock titan 550 motors that came with the truck. The esc I'm using is an Hobbywing platinum 100amp airplane esc. I'm using a 3cell 30c 3000mah lipo. Thats all for now. Be back in hour. Stay tuned
              Reaper.
              • SweetZ28
                • 1535
                cool hope all goes well.
                WWW.PPRSLOTS.COM
                • Rumdog
                  • 6667
                  How'd it work without pistix? What tx, The tactic?
                  • soulreaper
                    • 58
                    Rumdog I didn't use the Pistix because it would not let me go full throttle. I figured out how to get by without it. I had no issues at all. In my "PISTIX HELP" post, I mentioned that I could get the esc to arm and learn max and low throttle but once you unplugged the battery and then plugged it back in you had to repeat the throttle postion learning again. This went away when the Pistix was plugged into the system. I dont know why but it did. Anyway I found out that with the Pistix removed all I had to do was turn on the tx and hold or rubber band the brake to full on, during power up. After it armes let go or remove rubber band and let the trigger return to neutral positon. Works fine after that. Problem solved.
                    l
                    Reaper
                    • soulreaper
                      • 58
                      THIS IS GOING TO BE A LONG POST. Second test was very good. No major problems. The prop was a little small, but the boat still got up on plane fairly quick. The EZrun motor never got hot. In fact it was barely warm (hard to believe right?) but its true, this motor has so much torque its not funny. Anyway the esc as far as I could tell did not get to hot because it Never shut off. Prop walk WAS controllable this time around. The motor reached Max rpm after the first twenty feet. I know this is true because if the motor did not reach max rpm it would have heated up, but it didnt. I dont have any speed measuring devices but Im pretty sure I broke the twenty mph barrier. I did not go faster because prop is a little small and the motor reached max load rpm. The motor is a 2350kv x 11.1v=26085 no load rpm right? Since prop walk is controllable I dont know if I should increase prop size or buy a four cell 14.8v lipo and try that. That would give me a no load rpm of 34780 right? Boat would go faster and the walk would still be controllable.
                      Minor problem. After the Rio comes on plane and picks up speed it seems to sink down lower in the water and starts to plow the water instead of running ontop of it. I figure the extra weight of the 4th cell might help with that. SUGGESTIONS please.
                      Reaper
                      • Rumdog
                        • 6667
                        tyr to get the cg farther back. got any pics? It should be around 28-30 percent from the transom. What mah lipos are you running? The prob could be the motor is physically too large and adding too much weight forward of the cg. that hull only really needs a 540s or 380l to push it well into the high thirties.
                        • soulreaper
                          • 58
                          I think your right about the cg being off, but everything that I have installed except for the motor are in the orginal places( water tight box). Besides adding a heavier battery I dont know how to move the cg back. Your right about the motor is it heavier than than most brushless motors. I used this one because I had it on hand, and did not have to order. Im running 3000mah. Since you read my post about the tests what do you recommend I do. Bigger prop for speed or bigger lipo for speed and CG?
                          Reaper
                          • Rumdog
                            • 6667
                            Bigger prop is gonna give you prop walk. Order up some plastic props from ose. Stay under 40mm and you should have little propwalk. If yo ran 2s2p for 4s total you could run them parallel the motor in the back of the hull. You would prob. have to lose the radio box though.
                            • soulreaper
                              • 58
                              Rumdog thanks for the advice. I'll probably end up trying a 4cell for the CG. I dont know enough and I dont have the skill needed to relocate the motor to the back of the boat.
                              Reaper.
