5mm to 1/8 motor coupler
  • soulreaper
    • 58
    I have a Rio EP. I plan on going brushless. Most of the brushless motors that I have considered have a 5mm shaft. The Rio has a 1/8 flex cable. I need a motor coupler that will fit. I checked the couplers Offshore has, but they dont have the one I need. Does anyone know where I could get one?
  • Jeff Wohlt
    • 2740
    I make the set screw style. If this is going to be a hot boat with this upgrade then I would be happy to make more for anyone needing them.
    Is the flex a true 1/8" or is is a 130 cable? 130 cable is around a 127 dia. If you can check the true id of the 1/8" cable I can get them on the money. Try some digi calipers and let me know.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • soulreaper
      • 58
      Thank you so much. I will find out and let you know. Thanks again.
      Reaper
      • soulreaper
        • 58
        "Got Rpm" from RCU said that Offshore Electrics Octura Coupler Flex hex 5mm to .130 would work. Im going to give it a try. Wish me luck. Thanks
        Reaper
        • soulreaper
          • 58
          Update, I got the above listed coupler in the mail yesterday. I works like a charm.
          Reaper.
